Shop the Holiday Gift Guide
Asus Chromebook C300MA-BBCLN12 Battery Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
85
All Time:
1,027
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to open the casing on your Chromebook and remove your battery to replace it.
Parts
Tools
    1. Asus Chromebook C300MA-BBCLN12 Battery Replacement, Battery: step 1, image 1 of 2 Asus Chromebook C300MA-BBCLN12 Battery Replacement, Battery: step 1, image 2 of 2
      • Remove the eight 9.0mm Phillips #00 screws.
      • Remove the three 6.0mm Phillips #00 screws.
      Ask FixBot
    2. Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 2, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 2, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 2, image 3 of 3
      • Separate the palm rest assembly from the bottom housing using the plastic opening tool.
      • It is recommended that you start from a corner and run the plastic opening tool along the edge of the housing.
      • Lift the palm rest assembly slowly to prevent damaging the two cables that connect it to the motherboard.
      Ask FixBot
    3. Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 3, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 3, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Flip back the hinges on the connectors that secure the wide black cable and the narrow white cable using the tweezers.
      • Disconnect the wide black cable from the motherboard by pulling the blue cable tab away from the connector.
      • Disconnect the white ribbon cable from the motherboard by pulling the blue cable tab away from the connector.
      Ask FixBot
    4. Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 4, image 1 of 1
      • Remove the six 6.0mm Phillips #00 screws that secure the battery to the bottom housing.
      Ask FixBot
    5. Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 5, image 1 of 2 Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 5, image 2 of 2
      • Disconnect the bundled cable connector that attaches the battery to the motherboard using the small plastic spudger.
      Ask FixBot
    6. Asus Chromebook C300MA-BBCLN12 Battery Replacement: step 6, image 1 of 1
      • Remove the battery from the bottom housing.
      Ask FixBot
Author
with
Brooke Austin
419 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 85
All Time: 1,027
