How to Make a Jeans Patch Less Noticeable
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
46
Past 30 Days:
177
All Time:
1,495
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 40 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This repair guide demonstrates how to not only fix a hole in jeans but also make the hole less prominent. Patching a hole in the pocket is easy but sometimes the color of the patch doesn’t match the jeans, making it look awkward. Creating a design on the backside of the jeans will repurpose jeans that were not going to be worn. This will ultimately reduce waste because it allows us to repurpose a pair of jeans that would have been discarded.
    1. How to Make a Jeans Patch Less Noticeable, How to Make a Jeans Patch Less Noticeable: step 1, image 1 of 2 How to Make a Jeans Patch Less Noticeable, How to Make a Jeans Patch Less Noticeable: step 1, image 2 of 2
      • Place the jeans on an even surface.
      • Flip your jeans inside out.
      Ask FixBot
    2. How to Make a Jeans Patch Less Noticeable: step 2, image 1 of 3 How to Make a Jeans Patch Less Noticeable: step 2, image 2 of 3 How to Make a Jeans Patch Less Noticeable: step 2, image 3 of 3
      • Trim any loose thread around the hole.
      • After cleaning the area, use the iron to warm the area before placing the patch.
      Ask FixBot
    3. How to Make a Jeans Patch Less Noticeable: step 3, image 1 of 2 How to Make a Jeans Patch Less Noticeable: step 3, image 2 of 2
      • Grab the patch and iron it on until it is secured to the jeans.
      Ask FixBot
    4. How to Make a Jeans Patch Less Noticeable: step 4, image 1 of 3 How to Make a Jeans Patch Less Noticeable: step 4, image 2 of 3 How to Make a Jeans Patch Less Noticeable: step 4, image 3 of 3
      • Start preparing your thread and needle and knot the end of the thread.
      • Push the needle from the back to the front.
      • Create an outline of the part where the patch is visible, until a circle is formed.
      Ask FixBot
    5. How to Make a Jeans Patch Less Noticeable: step 5, image 1 of 3 How to Make a Jeans Patch Less Noticeable: step 5, image 2 of 3 How to Make a Jeans Patch Less Noticeable: step 5, image 3 of 3
      • Push the needle from the back to the front, filling in the hole.
      • Repeat this process until the hole is covered and the patch is not showing.
      • Tie off the thread in a knot on the inside of the jeans.
      Ask FixBot
    6. How to Make a Jeans Patch Less Noticeable: step 6, image 1 of 2 How to Make a Jeans Patch Less Noticeable: step 6, image 2 of 2
      • Grabbing a new color thread, tie off a knot like mentioned in step 4.
      • Starting inside, create your desired design (we decided a moon and stars).
      • Push the needle back to front creating little clumps within the hole.
      • When you have finished the design tie it off on the inside of the jeans.
      Ask FixBot
    7. How to Make a Jeans Patch Less Noticeable: step 7, image 1 of 1
      • Cut a new piece of thread and place it on the inside.
      • Push the needle back to front of the jeans and push it back inside a few centimeters down.
      • Repeat this threading technique a few times, creating a star.
      • Tie off the thread on the inside of the jean.
      • Cut any excess thread from the inside of the jean.
      • Jeans are now ready to be worn.
      Ask FixBot
Finish Line
Alejandra Gonzalez Manzo
145 Reputation
1 Guide authored
UC Davis, Team 2-5, Whithaus Spring 2024 Member of UC Davis, Team 2-5, Whithaus Spring 2024
UCD-WHITHAUS-S24S2G5
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 46
Past 30 Days: 177
All Time: 1,495
