Introduction
Go to step 1 ↓Follow this guide to machine wash a wader garment.
For most brands, machine washing is acceptable if it's done infrequently and carefully. Frequent or improper machine washing can damage waders over time.
Parts
Shake off any excess dirt, zip all zippers, and remove any detachable parts like waistbands or belts.
Untangle any straps.
Close or clip any fasteners or buckles.
Put your waders in the washing machine.
Add detergent to the washing machine. You can use special technical gear soap or gentle laundry detergent.
Set the load size to small.
Set the water temperature to cold.
Set the wash cycle to normal or gentle/delicate/permanent press. If possible, add an extra rinse cycle to ensure all residues are removed.
Set the spin cycle to low.
Start the washing machine.
Let your waders drip dry as soon as possible by hanging them somewhere and letting excess water drip off.
Air dry the inside of your waders by turning them inside-out and hanging them in a shaded, well-ventilated area until the inside is completely dry.
Air dry the outside of your waders by turning them right-side-out and hanging them in a shaded, well-ventilated area until the outside is completely dry.
Store your waders properly by hanging them by the shoulder straps or on a specialty wader hanger in a well-ventilated storage space.
