How to Lengthen a Pair of Shorts
  1. How to Lengthen a Pair of Shorts, How to Lengthen a Pair of Shorts: step 1, image 1 of 3 How to Lengthen a Pair of Shorts, How to Lengthen a Pair of Shorts: step 1, image 2 of 3 How to Lengthen a Pair of Shorts, How to Lengthen a Pair of Shorts: step 1, image 3 of 3
    • Pick a pair of shorts you would like to lengthen.
  2. How to Lengthen a Pair of Shorts: step 2, image 1 of 3 How to Lengthen a Pair of Shorts: step 2, image 2 of 3 How to Lengthen a Pair of Shorts: step 2, image 3 of 3
    • Cut up some fabric using a pair of scissors from any pair of pants you no longer need.
    • Feel free to measure it to the desired length you want.
    • Be careful when cutting with the scissors.
  3. How to Lengthen a Pair of Shorts: step 3, image 1 of 3 How to Lengthen a Pair of Shorts: step 3, image 2 of 3 How to Lengthen a Pair of Shorts: step 3, image 3 of 3
    • Cut the folded part at the bottom and unfold the shorts.
  4. How to Lengthen a Pair of Shorts: step 4, image 1 of 2 How to Lengthen a Pair of Shorts: step 4, image 2 of 2
    • Unfold the bottom and iron it out to make the hem straighter and cleaner.
  5. How to Lengthen a Pair of Shorts: step 5, image 1 of 3 How to Lengthen a Pair of Shorts: step 5, image 2 of 3 How to Lengthen a Pair of Shorts: step 5, image 3 of 3
    • Turn the pants inside out.
    • Line the fabric strips to the bottom of the shorts. The right sides should be together.
    • Align the raw edges and begin sewing either by hand or machine.
  6. How to Lengthen a Pair of Shorts: step 6, image 1 of 3 How to Lengthen a Pair of Shorts: step 6, image 2 of 3 How to Lengthen a Pair of Shorts: step 6, image 3 of 3
    • Sew the fabric strips to the shorts using a straight stitch along the lined edge.
    • Finish sewing and turn the shorts back to the front.
  7. How to Lengthen a Pair of Shorts: step 7, image 1 of 3 How to Lengthen a Pair of Shorts: step 7, image 2 of 3 How to Lengthen a Pair of Shorts: step 7, image 3 of 3
    • Fold the fabric down and press the seam.
    • Sew a second straight stitch along the folded edge for a clean finish.
    • Repeat the process for both legs of the shorts to make sure they are even.
Finish Line
Precious Uwadia
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 27
All Time: 445
