How to Install the Self Repair Assistant App
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. How to Install the Self Repair Assistant App, Download the app: step 1, image 1 of 3 How to Install the Self Repair Assistant App, Download the app: step 1, image 2 of 3 How to Install the Self Repair Assistant App, Download the app: step 1, image 3 of 3
    • Download the Self Repair Assistant app (2.0.12)here.
    • You may be prompted with a "File might be harmful" warning. If so, select "Download anyway."
    • Open the "My Files" app.
    • Navigate to the "Installation files" tab on the left side of the screen.
  2. How to Install the Self Repair Assistant App, Install the app: step 2, image 1 of 2 How to Install the Self Repair Assistant App, Install the app: step 2, image 2 of 2
    • Select the app on the right side of the screen.
    • If the app doesn't show up on this panel, skip to the next step.
    • Select "Install" to confirm the app's installation.
    • Skip the next two steps.
  3. How to Install the Self Repair Assistant App, Rename the app: step 3, image 1 of 3 How to Install the Self Repair Assistant App, Rename the app: step 3, image 2 of 3 How to Install the Self Repair Assistant App, Rename the app: step 3, image 3 of 3
    • If your app didn't show up on the "Installation files" tab, follow the next two steps to rename the file.
    • Navigate to the "Downloads" tab on the left side of the screen.
    • Long press the download file until an orange checkmark appears to the left of it.
    • Navigate to the bottom of the screen and select the "More" option.
  4. How to Install the Self Repair Assistant App: step 4, image 1 of 3 How to Install the Self Repair Assistant App: step 4, image 2 of 3 How to Install the Self Repair Assistant App: step 4, image 3 of 3
    • Select the "Rename" option.
    • Delete the .jar at the end of the app's name.
    • Your file should now appear in the "Installation files" tab.
The Self Repair Assistant app is installed and ready for use.
If you need to calibrate the optical fingerprint sensor, follow this guide.
If you need to reset your battery cycle count, follow this guide.
2 other people completed this guide.
Alex Diaz-Kokaisl
213,664 Reputation
1,040 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,656 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 111
All Time: 2,110
