How to Install the Handle for your Framework Desktop
    1. How to Install the Handle for your Framework Desktop, Remove the Top Panel screws: step 1, image 1 of 3 How to Install the Handle for your Framework Desktop, Remove the Top Panel screws: step 1, image 2 of 3 How to Install the Handle for your Framework Desktop, Remove the Top Panel screws: step 1, image 3 of 3
      • Use your finger to lift up the two D-rings on the Top Panel screws.
      Ask FixBot
    2. How to Install the Handle for your Framework Desktop: step 2, image 1 of 3 How to Install the Handle for your Framework Desktop: step 2, image 2 of 3 How to Install the Handle for your Framework Desktop: step 2, image 3 of 3
      • Use your fingers to twist the screw counter-clockwise and loosen it.
      • Remove the Top Panel screw.
      Ask FixBot
    3. How to Install the Handle for your Framework Desktop: step 3, image 1 of 3 How to Install the Handle for your Framework Desktop: step 3, image 2 of 3 How to Install the Handle for your Framework Desktop: step 3, image 3 of 3
      • Repeat the same procedure for the other Top Panel screw.
      Ask FixBot
    4. How to Install the Handle for your Framework Desktop, Adjust the Handle: step 4, image 1 of 2 How to Install the Handle for your Framework Desktop, Adjust the Handle: step 4, image 2 of 2
      • Rotate the screw threads on both sides counterclockwise to ensure they're as high up as they go. Otherwise, they might not install correctly.
      Ask FixBot
    5. How to Install the Handle for your Framework Desktop, Place the Handle: step 5, image 1 of 2 How to Install the Handle for your Framework Desktop, Place the Handle: step 5, image 2 of 2
      • Place the Handle over the Top Panel screw holes.
      Ask FixBot
    6. How to Install the Handle for your Framework Desktop, Secure the Handle: step 6, image 1 of 2 How to Install the Handle for your Framework Desktop, Secure the Handle: step 6, image 2 of 2
      • While holding the Handle in place, twist the screw threads on both sides clockwise until they're snug on the Top Panel.
      Ask FixBot
If you need help, contact Framework support.
Alex Diaz-Kokaisl
249,892 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 66
All Time: 488
