Shop the Holiday Gift Guide
How to Install and Remove Expansion Cards
View statistics:
Past 24 Hours:
14
Past 7 Days:
28
Past 30 Days:
88
All Time:
556
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 seconds - 1 minute
Difficulty: Very easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
This guide shows how to install and remove Expansion Cards for your Framework Desktop.
The Expansion Cards are hot-swappable. You can install and remove them without turning off your desktop.
For information on Expansion Card compatibility, click here.
    1. How to Install and Remove Expansion Cards, Reposition the Desktop: step 1, image 1 of 2 How to Install and Remove Expansion Cards, Reposition the Desktop: step 1, image 2 of 2
      • Rotate the Desktop so its rear rests on your work surface.
      • If your Desktop is plugged in, consider powering down and unplugging it so the rear sits flat. Otherwise, you'll need to support it with one hand at an angle while you work.
      Ask FixBot
    2. How to Install and Remove Expansion Cards, Install an Expansion Card: step 2, image 1 of 3 How to Install and Remove Expansion Cards, Install an Expansion Card: step 2, image 2 of 3 How to Install and Remove Expansion Cards, Install an Expansion Card: step 2, image 3 of 3
      • The next two steps show how to install an Expansion Card.
      • Slide an Expansion Card into an Expansion Card slot.
      • You don't need to unlock the latch to install the Expansion Cards—only when you want to remove them.
      • The Expansion Cards should click into place, and the front edge should be flush with the silver base.
      Ask FixBot
    3. How to Install and Remove Expansion Cards: step 3, image 1 of 2 How to Install and Remove Expansion Cards: step 3, image 2 of 2
      • If there's a red bar showing under the Expansion Card latch, use your finger to flip the latch and lock the Expansion Card into its slot.
      • Locking the Expansion Card slots helps keep the cards in place when you unplug cables from them.
      Ask FixBot
    4. How to Install and Remove Expansion Cards, Remove an Expansion Card: step 4, image 1 of 2 How to Install and Remove Expansion Cards, Remove an Expansion Card: step 4, image 2 of 2
      • The next two steps show how to remove an Expansion Card.
      • Use your finger to flip the Expansion Card latch into the unlocked position.
      • The latch displays a red bar when it's unlocked.
      Ask FixBot
    5. How to Install and Remove Expansion Cards: step 5, image 1 of 3 How to Install and Remove Expansion Cards: step 5, image 2 of 3 How to Install and Remove Expansion Cards: step 5, image 3 of 3
      • Push up on the lip of the Expansion Card with your fingers.
      • Pull the Expansion Card out of its slot and remove it.
      Ask FixBot
If you need help, contact Framework support.
Author
with
Alex Diaz-Kokaisl
252,477 Reputation
1,200 Guides authored
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 28
Past 30 Days: 88
All Time: 556
