Introduction
This guide shows you how to install the shoulder buttons (L + R) in the bottom shell of your Nintendo Game Boy Advance SP.
If the hinge pin fell out when removing the shoulder button, put it back into place.
Slide the spring into the shoulder button so the bent arm goes into the cutout on the inside edge.
Use your fingers to hold the spring in place and slide the button over the hinge pin and into its recess.
Use your finger, a spudger, or a pair of tweezers to rotate the spring arm into its clip.
Repeat the process to install the other shoulder button.
Return to your original repair guide and continue with reassembly.
2 other people completed this guide.
1 Guide Comment
Thanks for adding this small guide, linked from the 'How to Reshell' guide. The springs of my shoulder buttons fell out during disassembly and this made it so much easier and less stressful, knowing I was doing it right. Everything works perfect again, including a stuck button (I had to replace the rubber pad)
