How to Hand Stitch a Ripped Seam
  1. How to Hand Stitch a Ripped Seam, How to Hand Stitch a Ripped Seam: step 1, image 1 of 1
    • Obtain a roll of thread that matches the color of the clothing and a threading needle.
  2. How to Hand Stitch a Ripped Seam: step 2, image 1 of 1
    • Measure out a piece of thread the length of your wingspan. Then, take about 10 more inches than that.
    • The thicker the fabric, the more thread you should use.
  3. How to Hand Stitch a Ripped Seam: step 3, image 1 of 1
    • Thread the need so that the needle falls exactly in the middle of the thread.
    • If you have trouble threading it, you can wet it and roll it so it’s easier or use a needle threader.
  4. How to Hand Stitch a Ripped Seam: step 4, image 1 of 1
    • Now, tie a knot at the end of the thread about 2 inches away from the end of the thread.
    • Tie the knot multiple times in the same place so that it is big enough to keep that end from slipping through the fabric.
  5. How to Hand Stitch a Ripped Seam: step 5, image 1 of 1
    • Turn the clothing inside out and insert the needle at the end of the rip.
  6. How to Hand Stitch a Ripped Seam: step 6, image 1 of 3 How to Hand Stitch a Ripped Seam: step 6, image 2 of 3 How to Hand Stitch a Ripped Seam: step 6, image 3 of 3
    • Now, push the needle back through the other side a space away from the initial piercing spot.
    • Then, go back through the initial piercing spot (the end of the first stitch) through the back this time.
  7. How to Hand Stitch a Ripped Seam: step 7, image 1 of 3 How to Hand Stitch a Ripped Seam: step 7, image 2 of 3 How to Hand Stitch a Ripped Seam: step 7, image 3 of 3
    • Poke the needle through the fabric another space away from the previous stitch and stitch back through again then, repeat.
  8. How to Hand Stitch a Ripped Seam: step 8, image 1 of 1
    • Continue this pattern until the hole is completely closed.
  9. How to Hand Stitch a Ripped Seam: step 9, image 1 of 3 How to Hand Stitch a Ripped Seam: step 9, image 2 of 3 How to Hand Stitch a Ripped Seam: step 9, image 3 of 3
    • Begin to tie off the knot by looping the needle and thread over and under the bottom of the last stitch you made.
    • Then, loop the needle and thread over and under the bigger loop that your first loop created and pull to fasten the knot.
    • Clip any extra thread that is left over.
Indigo Young
169 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 1,429
