How to Fix the Siemens Washing Machine E18 Error Code
View statistics:
Past 24 Hours:
12
Past 7 Days:
56
Past 30 Days:
277
All Time:
895
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Video Guide This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓
Use this guide to clear an E18 error on a Siemens washing machine caused by a blocked pump filter. The pump filter, also called the drain pump filter, drainage pump filter, or coin trap, catches debris before it reaches the drain pump. When it clogs, the washer may stop mid-cycle and fail to drain. This procedure applies to many Siemens front-loading washers with a lower-right pump filter access panel; some models may have minor panel differences.
      • Confirm the display shows E18 and the washer has stopped draining, often mid-cycle.
      • Remove any wet washing from the drum.
      • Disconnect power by switching off at the plug or unplugging the washer before opening the service area.
      • Turn off the power supply cold water feed.
      Ask FixBot
      • Find the small plastic service panel on the lower right front of the washer.
      • Push down the clip at the top of the panel and pull the panel off.
      • Identify the small drain hose and the pump filter behind the panel.
      Ask FixBot
      • Place a small tray under the small drain hose.
      • Pull the hose out a little.
      • Unclip the small cap on the end of the hose and let the water drain into the tray.
      • The hose drains most of the water from the pump filter area, but some water will still remain.
      • Clip the cap back on securely and put the hose back in place after the water stops draining.
      • Leaving the cap off will let water spill onto the floor during the next wash.
      Ask FixBot
      • Place the small tray under the pump filter and lay a small towel on the floor.
      • Turn the pump filter counterclockwise slowly, but don't remove it completely yet.
      • Let the remaining water drain into the tray.
      • If the tray fills or water comes out too quickly, turn the filter clockwise to tighten it, empty the tray, and loosen the filter again.
      Ask FixBot
      • Turn the pump filter counterclockwise slowly until it comes free.
      • Remove coins, hair clips, and any other debris from the filter.
      • Look inside the filter opening and remove anything else that is stuck inside.
      Ask FixBot
      • Use a flat-blade screwdriver to nudge the pump propeller and confirm it turns freely.
      • Don't force the propeller if it won't move, because the pump may still be blocked or damaged.
      • Rinse a gunky or dirty filter under hot water.
      • Leave a clean, undamaged filter as it is.
      Ask FixBot
      • Insert the pump filter into the opening and turn it clockwise.
      • Keep turning until the filter locks in the upright position.
      • Make sure the drain hose cap is clipped on securely and the hose is back in place.
      • Leave the lower front service panel off for the first test so you can check the filter for leaks.
      • Turn the cold water feed back on slowly.
      Ask FixBot
      • Make sure your hands are dry, then restore power at the plug.
      • Put the wet washing back in or load a wash, close the door, and start a short cycle.
      • Use a 30 minute quick wash if your Siemens model has that option.
      • Watch the pump filter area during the test cycle.
      • If water leaks from the filter area, stop the washer, disconnect power, and reseat the filter and drain hose cap.
      • Fit the lower front service panel after the filter stays dry.
      Ask FixBot
      • Check the drainage hose for a blockage if the E18 error returns after the filter is clean.
      • Check the U-bend for a blockage if the drainage hose is clear.
      • Stop the cycle and clean the filter as soon as possible if the pump makes strange noises.
      • Check pockets before washing to keep coins and hair clips out of the pump filter.
      • Clean the pump filter about once a year to prevent drainage problems.
      • If E18 remains and the pump propeller doesn't turn freely, the pump may be damaged and will need further diagnosis.
      Ask FixBot
The washer should drain normally after the blockage is removed, the filter is sealed, and the test cycle runs without leaks. Repair didn't go as planned? Ask our Answers community for help.
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 56
Past 30 Days: 277
All Time: 895
