Up to 20% off select tools
How to Fix the LG Washing Machine LE Error Code
Views: 5.1K
View statistics:
Past 24 Hours:
38
Past 7 Days:
233
Past 30 Days:
999
All Time:
5,065
Comments: 3
3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Video Guide
This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓
If your LG (or LG-built Kenmore) washing machine shows the LE error code, makes a grinding or bumping noise, and won’t spin properly, the washer is detecting a motor lock issue. This guide shows how to reset the control, check for physical obstructions, and diagnose and replace the rotor position sensor (RPS), which is a common cause of the LE code.
      • Unplug the washing machine, and let it sit for 2–3 minutes.
      • Press and hold the power button for 5–10 seconds while the unit is unplugged.
      • Plug the washing machine back in, and confirm the LE code disappears.
      • Run a cycle to drain any water left in the drum.
      • This reset alone may clear the LE error if the fault was temporary.
      Ask FixBot
      • Open the door, and spin the drum by hand to check for abnormal noise or sudden stopping.
      • If the drum stops abruptly or makes major noise, an internal obstruction may require tub disassembly, which isn’t shown in this video.
      Ask FixBot
      • Unplug the washing machine.
      • Move the washer to access the rear metal panel.
      • Use a Phillips screwdriver to remove the four screws from the rear panel.
      • Slide the rear panel off to expose the motor area.
      Ask FixBot
      • Use a 17 mm socket wrench to turn the rotor bolt counterclockwise.
      • Hold the rotor in place so it doesn’t turn while you loosen the bolt.
      • Tap the socket wrench with a rubber hammer to help break the bolt loose if it’s tight.
      • Remove the rotor bolt fully once it’s loose.
      Ask FixBot
      • Pull the rotor straight off the shaft using equal pressure with both hands.
      • Caution: The rotor contains large magnets, so it can be difficult to remove.
      • Caution: Don’t pull from only one side, or you could damage the magnets.
      • Wiggle the rotor gently and evenly on both sides while pulling if needed.
      Ask FixBot
      • Inspect the rotor hub threads for severe wear.
      • Some models let you replace only the rotor hub using three screws.
      • Inspect the rotor magnets for smooth surfaces without wear, cracks, burning, damage, or obstructions.
      • Damaged magnets can’t be replaced individually, so the rotor assembly would need replacement.
      Ask FixBot
      • Use a 10 mm socket wrench to remove the six long screws holding the stator.
      • Caution: Support the stator while removing the last screw, because it can fall.
      • Hold the stator with one hand, and disconnect the two wire harnesses.
      • Use a flat-bladed screwdriver or needle-nose pliers to press the clip sides if the connectors are stuck.
      Ask FixBot
      • Inspect the stator magnet edges and the stator wiring for burn marks or damage.
      • If the stator shows visible damage, it likely needs replacement, but replacement isn’t shown in this video.
      Ask FixBot
      • Locate the rotor position sensor on the inside of the stator ring.
      • Use a flat-bladed screwdriver to press in on the sensor’s retaining tab, and remove the sensor from the stator.
      • The sensor is held by an inner retaining tab and three outer tabs.
      Ask FixBot
      • Set a multimeter to resistance (ohms).
      • If the multimeter isn’t self-ranging, set it to 20 kΩ.
      • Measure resistance between connector 5 and connector 1, and confirm the reading is 5–15 kΩ.
      • Measure resistance between connector 5 and connector 2, and confirm the reading matches and is 5–15 kΩ.
      • A reading far outside this range indicates a bad sensor.
      Ask FixBot
      • Snap the new sensor onto the three outer pegs on the stator ring.
      • Snap the sensor onto the inner peg so it locks in place securely.
      • Inspect the stator wiring and harness connectors for frayed wires, damage, or separated connector wires.
      Ask FixBot
      • Position the stator on the tub, and start two bolts by hand to hold it in place.
      • Thread the two bolts only partway so the stator can’t move.
      • Reconnect the two wire harnesses to the stator.
      • The connectors only install one way.
      • Use a 10 mm socket wrench to install the other four bolts, and fully tighten all six bolts.
      Ask FixBot
      • Align the rotor hub threads with the tub shaft, and set the rotor onto the stator.
      • Caution: The magnets can pull the rotor hard into place, so keep the rotor aligned as you seat it.
      • Press the rotor toward the tub if needed so the bolt can start threading into the shaft.
      • Apply five or six drops of blue threadlocker to the rotor bolt threads.
      • Use a 17 mm socket wrench to tighten the rotor bolt, then tap the wrench with a hammer a few times to ensure it’s tight.
      Ask FixBot
      • Slide the rear panel into place.
      • Use a Phillips screwdriver to install the four rear panel screws.
      • Move the washing machine back into place, plug it in, and confirm the hoses are connected.
      • Run a test cycle, and confirm the washer runs smoothly and spins properly without thunking noises.
      Ask FixBot
Reinstall the rear panel and run a test cycle to confirm the LE code is cleared before returning the washer to service. Repair didn't go as planned? Ask our Answers community for help.
2 other people completed this guide.
Author
with
Ben Schlichter
7,269 Reputation
224 Guides authored
3 Guide Comments
عندما يتعطل النظام الغسالة بمعناال جي إلي هوا الشريحة ما الحل
عبدالحكيم محمد - Reply Share
Make note your front loader lg washer direct drive doesn’t have a posion sensor it has coils
Tera Kellerman - Reply Share
Beste Anleitung im Netz! Danke dafür. Bei mir war der Sensor defekt, obwhl die Messwerte des Sensors bei alt und neu gleich waren (warum auch immer). nach Tausch des Sensors, lief alles wieder normal. Vor allem der Text, der die Schritte erklärt, war eine große Hilfe. Nochmal danke!!
Da Ko - Reply Share
Past 24 Hours: 38
Past 7 Days: 233
Past 30 Days: 999
All Time: 5,065
