How to Fix the Frigidaire Stove F11 Error Code
Video Guide
This guide was transcribed from a YouTube video.
      • Gather isopropyl alcohol, cotton swabs, a headlamp, a 1/4 inch nut driver, a Phillips screwdriver, and a #6 Robertson screwdriver.
      • Turn off the stove breaker before moving or opening the stove.
      • Let the stove cool completely, pull it out only as far as needed, and unplug the power cord.
      • Keep the power cord and any gas line from stretching, kinking, or pinching while moving the stove.
      • Use a headlamp or flashlight if the area behind the stove is hard to see.
      Ask FixBot
      • Use a 1/4 inch nut driver and a #6 Robertson screwdriver to remove the six screws from the rear panel.
      • This stove used two 1/4 inch hex-head screws and four #6 Robertson screws, but other models may differ.
      • Leave the top middle screw in place until the other screws are out.
      • Support the panel while removing the top middle screw so it doesn't fall.
      • Lift off the rear panel to expose the back of the control module.
      Ask FixBot
      • Take reference photos of the control module, screw locations, and wire positions before removing the module.
      • Use a Phillips screwdriver to remove the four screws securing the control module.
      • Place the screws in a small dish so they don't get lost.
      • Pull the loosened control module out just enough to reach the wire plugs.
      Ask FixBot
      • Take a clear photo of every plug from left to right so the wiring can go back in the same places.
      • Release any retaining clips before pulling the connectors off.
      • Pull on the connector bodies, not the wires, to avoid damaging the wiring.
      • Unplug every connector, including the grounding wire fourth from the left.
      • Set the control module on a clean, dry work surface.
      Ask FixBot
      • Peel the black plastic front face off the control module.
      • Peel only the black plastic layer, not the small circuit board behind it.
      • Work slowly around sticky areas until the contact surface is exposed.
      • Inspect the exposed contacts for grease, moisture, dirt, or dark spots.
      • Clean every contact, even if only one or two look dirty.
      Ask FixBot
      • Pour a small amount of isopropyl alcohol into a clean small dish.
      • Keep isopropyl alcohol away from flames and hot surfaces, and don't restore power until it has evaporated.
      • Dip a cotton swab in the alcohol and scrub one exposed contact at a time.
      • Rewet the cotton swab as needed and clean every bit of the contact surface.
      • Switch to a fresh cotton swab when the swab becomes dirty.
      Ask FixBot
      • Use isopropyl alcohol and cotton swabs to clean the matching contact areas on the back of the plastic front face.
      • Clean the spots where the plastic face lines up with the circuit board contacts.
      • Keep cleaning each spot until the contact area looks clean.
      • Let the alcohol dry completely before reassembling the control module.
      Ask FixBot
      • Place the plastic front face back onto the circuit board.
      • Line it up carefully so the buttons sit in the correct places.
      • Press the face down across the surface so it sticks to the board.
      • Check the alignment before installing the control module in the stove.
      Ask FixBot
      • Use the reference photos to reconnect the plugs to their original sockets.
      • On this model, connecting the red plug first helps hold the control module while the other plugs are connected.
      • Push each plug in until it is fully seated.
      • Give each connector a gentle tug to confirm it is snug, but don't pull hard.
      • Slide the ground wire back onto its contact unless the contact is badly corroded.
      • Don't use the stove with a loose or corroded ground connection.
      Ask FixBot
      • Set the control module back into position and line up the screw holes.
      • Use a Phillips screwdriver to reinstall the four control module screws.
      • Tighten the screws until the module is secure, but don't overtighten them.
      Ask FixBot
      • Set the rear panel against the back of the stove and line up the holes.
      • Install the top middle screw first so the panel can support itself.
      • Use the 1/4 inch nut driver and #6 Robertson screwdriver to reinstall the remaining five screws in their original locations.
      • Confirm the rear panel is secure before moving the stove.
      Ask FixBot
      • Plug the power cord back in.
      • Slide the stove back into place without pinching the power cord or any gas line.
      • Turn the breaker on.
      • Check the display and listen for the beeping.
      • The F11 error and beeping should be gone if the contact cleaning worked.
      Ask FixBot
If the F11 error returns, disconnect power and recheck the cleaned contacts and wire plugs before considering a replacement control module. Repair didn't go as planned? Ask our Answers community for help.
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 68
All Time: 149
