Introduction
Go to step 1 ↓Use this guide to remove and clean the Aqua inlet filter on a Bosch Serie 4 VarioPerfect washing machine. The Aqua inlet filter, inlet filter, or cold water feed filter traps grit and dirt from the power supply cold water supply. A clogged filter can reduce water flow and trigger the tap warning icon, an F17 error, or an E17 error. This procedure applies to standard and Aqua-Secure models with the small rear inlet filter. AquaStop filters are different and aren't covered here.
Tools
TrayOptional
Step 1 Shut off power and water
Unplug the washing machine from the power supply power outlet.
Turn off the power supply cold water supply feeding the washing machine.
Step 2 Move the washing machine
Pull the washing machine out only far enough to reach the back.
Remove the drain hose from the U-bend pipe if you need more access behind the machine.
Step 3 Locate the Aqua inlet filter
Follow the power supply cold water inlet hose to the rear top corner of the washing machine.
Find the hose connection on the back of the machine.
Step 4 Disconnect the cold water feed hose
Place a small bucket or tray under the rear hose connection to catch water.
Grip the hose connector by hand and turn it anticlockwise to loosen it.
Keep unscrewing the connector until the hose comes away from the machine.
Place the end of the hose in the bucket or tray so it doesn't drip on the floor.
Step 5 Remove the inlet filter
Use a tissue or rag to dry the filter area inside the inlet.
Use pliers to grip the flat end of the filter that sticks out slightly from the inlet.
Pull the filter straight toward you while gently wiggling it free.
Step 6 Clean the filter
Inspect the perforated holes in the filter for grit, dirt, or debris.
Use a brush to scrub debris from the filter holes.
Blow through the filter to clear any remaining blockage.
Step 7 Reinstall the filter and hose
Hold the filter straight and push it back into the inlet with a finger until it seats fully.
Thread the cold water feed hose back onto the inlet by hand.
Tighten the hose connector as firmly as you can by hand.
Step 8 Turn the water back on
Slowly turn the power supply cold water supply back on.
Check the rear hose connection for leaks while the water pressure returns.
If the connection leaks, turn the water off, reseat the hose connector, and hand-tighten it again.
Step 9 Push the washing machine back
Push the washing machine back into place.
Watch the cold water feed hose and drain hose as you push the machine back.
Check that the cold water hose is free and not trapped behind the machine.
Step 10 Level the washing machine
Place a level on top of the washing machine.
Check that the machine is level.
Adjust the legs underneath the machine if it isn't level.
Step 11 Run final checks
Plug the washing machine back into the power supply outlet.
Run a short fill or wash cycle and confirm that water enters the machine normally.
Check behind the machine again for leaks while the machine fills.
If the F17 error, E17 error, or tap warning returns, recheck that the supply valve is fully open, the hose isn't kinked, and the filter is clean.
The Aqua inlet filter is clean when the washer fills normally and the rear hose connection stays dry. Repair didn't go as planned? Ask our Answers community for help.
