How to Fix a Stuck Trombone Tuning Slide
  1. How to Fix a Stuck Trombone Tuning Slide, How to Fix a Stuck Trombone Tuning Slide: step 1, image 1 of 3 How to Fix a Stuck Trombone Tuning Slide, How to Fix a Stuck Trombone Tuning Slide: step 1, image 2 of 3 How to Fix a Stuck Trombone Tuning Slide, How to Fix a Stuck Trombone Tuning Slide: step 1, image 3 of 3
    • Carefully remove the slides from the trombone.
    • If the slides are completely stuck, wiggle the slides from side to side while pulling it out of the trombone.
    Ask FixBot
  2. How to Fix a Stuck Trombone Tuning Slide: step 2, image 1 of 1
    • Clean each slide using a paper towel or cloth.
    • This will remove any friction the slides may have with the trombone.
    Ask FixBot
  3. How to Fix a Stuck Trombone Tuning Slide: step 3, image 1 of 1
    • Check to see if the tuning slides are parallel with their corresponding parts.
    • This can be done simply by aligning the slides against the trombone.
    Ask FixBot
  4. How to Fix a Stuck Trombone Tuning Slide: step 4, image 1 of 2 How to Fix a Stuck Trombone Tuning Slide: step 4, image 2 of 2
    • If the slides are parallel, skip to step six. If not, attach each individual slide to the trombone and push/pull in the direction in which it would be parallel.
    • This will straighten the warped slides back into place.
    • Warped slides can be very difficult to move when attached to the trombone.
    Ask FixBot
  5. How to Fix a Stuck Trombone Tuning Slide: step 5, image 1 of 2 How to Fix a Stuck Trombone Tuning Slide: step 5, image 2 of 2
    • Check to see if the slides are align once more.
    • Keep repeating step 4 if the slides are not lined up yet.
    Ask FixBot
  6. How to Fix a Stuck Trombone Tuning Slide: step 6, image 1 of 2 How to Fix a Stuck Trombone Tuning Slide: step 6, image 2 of 2
    • Apply tuning slide grease to each slide.
    • Make sure each slide only gets a thin layer of grease. Too much grease could cause friction when attached to the trombone.
    Ask FixBot
  7. How to Fix a Stuck Trombone Tuning Slide: step 7, image 1 of 1
    • Attach the slides back to the trombone.
    • Position the slides to your liking and enjoy playing!
    Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 45
All Time: 2,403
