How to Fix a Ripped Nylon Backpack Strap
    1. How to Fix a Ripped Nylon Backpack Strap, How to Fix a Ripped Nylon Backpack Strap: step 1, image 1 of 1
      • If your backpack strap is not fully removed, cut the threads holding the strap to the backpack, or gently pull threads out.
      Ask FixBot
    2. How to Fix a Ripped Nylon Backpack Strap: step 2, image 1 of 1
      • Cut the ripped or damaged part of your strap with scissors.
      • Do not cut too much of the backpack strap as you will use what is left over to sew it into the backpack.
      Ask FixBot
    3. How to Fix a Ripped Nylon Backpack Strap: step 3, image 1 of 2 How to Fix a Ripped Nylon Backpack Strap: step 3, image 2 of 2
      • Take a lighter and safely burn the ends of the backpack strap slightly.
      • Caution: If not safe, the lighter can cause you and your item damage, please use carefully.
      Ask FixBot
    4. How to Fix a Ripped Nylon Backpack Strap: step 4, image 1 of 3 How to Fix a Ripped Nylon Backpack Strap: step 4, image 2 of 3 How to Fix a Ripped Nylon Backpack Strap: step 4, image 3 of 3
      • Place the strap into the area where it will be reattached and hold it in place using a pin.
      • Make sure that you place a significant amount of the strap into the reattachment area .
      • Caution: The pin is sharp and can hurt you if not careful.
      Ask FixBot
    5. How to Fix a Ripped Nylon Backpack Strap: step 5, image 1 of 3 How to Fix a Ripped Nylon Backpack Strap: step 5, image 2 of 3 How to Fix a Ripped Nylon Backpack Strap: step 5, image 3 of 3
      • Cut your thread generously and run the thread through the needle.
      Ask FixBot
    6. How to Fix a Ripped Nylon Backpack Strap: step 6, image 1 of 3 How to Fix a Ripped Nylon Backpack Strap: step 6, image 2 of 3 How to Fix a Ripped Nylon Backpack Strap: step 6, image 3 of 3
      • Make a knot at the end by looping the thread around your finger and inserting the thread into the loop.
      • Do this twice.
      Ask FixBot
    7. How to Fix a Ripped Nylon Backpack Strap: step 7, image 1 of 3 How to Fix a Ripped Nylon Backpack Strap: step 7, image 2 of 3 How to Fix a Ripped Nylon Backpack Strap: step 7, image 3 of 3
      • Insert the needle through the backpack strap and pull it through.
      • From the backside of the backpack, insert the needle to the right of the original insertion.
      • From the front, insert the needle a little to the left of the original insertion and pull it through to create a backhand stitch.
      • Caution: The needle is very small and sharp and can easily hurt you.
      • If a beginner, it is recommended to use a thimble.
      Ask FixBot
    8. How to Fix a Ripped Nylon Backpack Strap: step 8, image 1 of 3 How to Fix a Ripped Nylon Backpack Strap: step 8, image 2 of 3 How to Fix a Ripped Nylon Backpack Strap: step 8, image 3 of 3
      • After repeating the process run the needle through the back of one of your seams.
      • Pull the thread through the created loop and pull to create a knot. Do this twice.
      Ask FixBot
    9. How to Fix a Ripped Nylon Backpack Strap: step 9, image 1 of 2 How to Fix a Ripped Nylon Backpack Strap: step 9, image 2 of 2
      • Cut the access string and remove the pin.
      Ask FixBot
spernil
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 24
Past 30 Days: 116
All Time: 299
