Introduction
Go to step 1 ↓A mirror frame can become damaged over time from accidental drops, stress, or age, leading to cracked sections, loose joints, or gaps that make the frame unstable or unattractive. This guide will show you how to repair broken or separated pieces of a decorative mirror frame using adhesive, filler, and paint so the frame looks strong and seamless again.
Gorilla Glue is used in this repair to bond broken pieces back together. Keep in mind that this type of glue expands slightly as it cures, so use it carefully to avoid excess buildup. If gaps remain after gluing, you will use clay or filler to rebuild missing areas before painting over the repair to match the frame’s original finish.
Before beginning, inspect your mirror for any loose debris and handle the frame gently to avoid stressing the glass.
Tools
Gather all your broken frame pieces and gently clean off any dust or debris. Once the pieces are clean, arrange them to determine how they fit back into the damaged section. This will help you understand the order in which they need to be glued.
Use tension bands (rubber bands or elastic straps) to hold the pieces tightly together while the glue cures. Place the bands so that they apply gentle, even pressure across the repaired area without pressing against the mirror glass. Let the glue dry according to the instructions on the adhesive bottle.
Once the glue is fully dry, check for any gaps or visible seams between the pieces. Use clay or wood filler to fill in the gaps to create a smooth, continuous surface. Shape the filler to match the pattern and curves of the existing frame. Allow the filler to dry completely before moving on.
