How to Fix a Loose Tape Measure Lock
    1. How to Fix a Loose Tape Measure Lock, How to Fix a Loose Tape Measure Lock: step 1, image 1 of 3 How to Fix a Loose Tape Measure Lock, How to Fix a Loose Tape Measure Lock: step 1, image 2 of 3 How to Fix a Loose Tape Measure Lock, How to Fix a Loose Tape Measure Lock: step 1, image 3 of 3
      • Remove the top and bottom screws from your tape measure using a Phillips head screwdriver.
      • The longer screw will be on the top, and the shorter screw will be on the bottom.
      Ask FixBot
    2. How to Fix a Loose Tape Measure Lock: step 2, image 1 of 3 How to Fix a Loose Tape Measure Lock: step 2, image 2 of 3 How to Fix a Loose Tape Measure Lock: step 2, image 3 of 3
      • Remove the screw that fastens the clip with your Phillips head screwdriver and place the clip to the side.
      Ask FixBot
    3. How to Fix a Loose Tape Measure Lock: step 3, image 1 of 3 How to Fix a Loose Tape Measure Lock: step 3, image 2 of 3 How to Fix a Loose Tape Measure Lock: step 3, image 3 of 3
      • Loosen the rubber housing from its contact points with a spudger and remove it from the back of the tape measure.
      • This may require some force.
      Ask FixBot
    4. How to Fix a Loose Tape Measure Lock: step 4, image 1 of 3 How to Fix a Loose Tape Measure Lock: step 4, image 2 of 3 How to Fix a Loose Tape Measure Lock: step 4, image 3 of 3
      • Remove the bottom screw with your Phillips head screwdriver.
      Ask FixBot
    5. How to Fix a Loose Tape Measure Lock: step 5, image 1 of 3 How to Fix a Loose Tape Measure Lock: step 5, image 2 of 3 How to Fix a Loose Tape Measure Lock: step 5, image 3 of 3
      • Pry open the yellow casing using your flathead screwdriver and lay down the halves so the internal components are facing up.
      Ask FixBot
    6. How to Fix a Loose Tape Measure Lock: step 6, image 1 of 3 How to Fix a Loose Tape Measure Lock: step 6, image 2 of 3 How to Fix a Loose Tape Measure Lock: step 6, image 3 of 3
      • Carefully remove the button and tooth, and remove the spring from the tooth.
      • There may also be a small black piece that falls out; set it aside for later reassembly.
      Ask FixBot
    7. How to Fix a Loose Tape Measure Lock: step 7, image 1 of 3 How to Fix a Loose Tape Measure Lock: step 7, image 2 of 3 How to Fix a Loose Tape Measure Lock: step 7, image 3 of 3
      • Use a nail file or 220-400 grit sandpaper to roughen the surface of the pad using around 5 passes.
      • Too many passes can shorten the pad/tooth, worsening contact with the blade.
      Ask FixBot
    8. How to Fix a Loose Tape Measure Lock: step 8, image 1 of 3 How to Fix a Loose Tape Measure Lock: step 8, image 2 of 3 How to Fix a Loose Tape Measure Lock: step 8, image 3 of 3
      • Place the tooth back into its housing while also pressing the spring into place.
      Ask FixBot
    9. How to Fix a Loose Tape Measure Lock: step 9, image 1 of 3 How to Fix a Loose Tape Measure Lock: step 9, image 2 of 3 How to Fix a Loose Tape Measure Lock: step 9, image 3 of 3
      • Apply pressure to the tooth and press the button back into place.
      • When leaving it untouched, the tooth should be applying pressure to the blade.
      Ask FixBot
    10. How to Fix a Loose Tape Measure Lock: step 10, image 1 of 3 How to Fix a Loose Tape Measure Lock: step 10, image 2 of 3 How to Fix a Loose Tape Measure Lock: step 10, image 3 of 3
      • Slightly retract the tape while holding the internal components in place.
      • Press the small remaining black piece back into place.
      Ask FixBot
    11. How to Fix a Loose Tape Measure Lock: step 11, image 1 of 3 How to Fix a Loose Tape Measure Lock: step 11, image 2 of 3 How to Fix a Loose Tape Measure Lock: step 11, image 3 of 3
      • Reattach the band to its loop, then place the empty shell of the tape measure on top of the side housing the mechanism.
      Ask FixBot
    12. How to Fix a Loose Tape Measure Lock: step 12, image 1 of 3 How to Fix a Loose Tape Measure Lock: step 12, image 2 of 3 How to Fix a Loose Tape Measure Lock: step 12, image 3 of 3
      • Screw in the front-bottom screw using your Phillips head screwdriver, recalling the order in which you removed them.
      Ask FixBot
    13. How to Fix a Loose Tape Measure Lock: step 13, image 1 of 3 How to Fix a Loose Tape Measure Lock: step 13, image 2 of 3 How to Fix a Loose Tape Measure Lock: step 13, image 3 of 3
      • Reattach the rubber housing and press it into place such that it is flush with the yellow housing.
      Ask FixBot
    14. How to Fix a Loose Tape Measure Lock: step 14, image 1 of 3 How to Fix a Loose Tape Measure Lock: step 14, image 2 of 3 How to Fix a Loose Tape Measure Lock: step 14, image 3 of 3
      • Reattach the clip using your Phillips head screwdriver.
      Ask FixBot
    15. How to Fix a Loose Tape Measure Lock: step 15, image 1 of 3 How to Fix a Loose Tape Measure Lock: step 15, image 2 of 3 How to Fix a Loose Tape Measure Lock: step 15, image 3 of 3
      • Reinsert the larger of the two remaining screws in the top hole.
      Ask FixBot
    16. How to Fix a Loose Tape Measure Lock: step 16, image 1 of 3 How to Fix a Loose Tape Measure Lock: step 16, image 2 of 3 How to Fix a Loose Tape Measure Lock: step 16, image 3 of 3
      • Reinsert the remaining screw in the bottom hole, and you have a repaired tape measure!
      Ask FixBot
Finish Line
Dante Olenick
253 Reputation
1 Guide authored
UC Davis, Team 1-3, Morris Winter 2026 Member of UC Davis, Team 1-3, Morris Winter 2026
UCD-MORRIS-W26S1G3
3 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 153
All Time: 446
