How to Fix a Leaking Garden Hose Connector
  1. How to Fix a Leaking Garden Hose Connector, Male Garden Hose Connector: step 1, image 1 of 1
    • Disconnect the hose and place the end on a stable surface.
    Ask FixBot
  2. How to Fix a Leaking Garden Hose Connector: step 2, image 1 of 2 How to Fix a Leaking Garden Hose Connector: step 2, image 2 of 2
    • Hold the hose down against the surface and use the utility knife to cut the hose about two to three inches away from the old connector.
    • Be careful cutting through the hose as the utility knife is very sharp and the hose is thick.
    Ask FixBot
  3. How to Fix a Leaking Garden Hose Connector: step 3, image 1 of 3 How to Fix a Leaking Garden Hose Connector: step 3, image 2 of 3 How to Fix a Leaking Garden Hose Connector: step 3, image 3 of 3
    • Insert the new male hose connector into the open end of the hose, pressing it in by hand as far as possible.
    • Use the pliers to assist with pushing the connector completely into the hose.
    • Make sure the connector is fit completely to the edge of the hose.
    Ask FixBot
  4. How to Fix a Leaking Garden Hose Connector: step 4, image 1 of 3 How to Fix a Leaking Garden Hose Connector: step 4, image 2 of 3 How to Fix a Leaking Garden Hose Connector: step 4, image 3 of 3
    • Take the stainless steel clamp and loosen the screw by hand or with the pliers until it will slide around the hose.
    Ask FixBot
  5. How to Fix a Leaking Garden Hose Connector: step 5, image 1 of 2 How to Fix a Leaking Garden Hose Connector: step 5, image 2 of 2
    • Place the clamp close to the connector but not too close, and begin to tighten it by turning the screw on the clamp.
    • Use the pliers once it starts to get harder or a flathead screwdriver if you have one.
    Ask FixBot
  6. How to Fix a Leaking Garden Hose Connector: step 6, image 1 of 2 How to Fix a Leaking Garden Hose Connector: step 6, image 2 of 2
    • To make sure there are no other leaks between the connector and the spout, wrap Teflon tape around the thread of your water source 2-3 times.
    • Twist the new hose connector to the water source.
    • Do this by hand or with the pliers until it is secure.
    • Finally, turn the water on and make sure there are no leaks from the new connector.
    Ask FixBot
Finish Line
5 other people completed this guide.
1 Guide Comment
Reverse steps 3 and 4 it will be easier.
lpproven - Reply Share
Past 24 Hours: 76
Past 7 Days: 282
Past 30 Days: 1,334
All Time: 1,845
