Introduction
Water damage is one of the most difficult disasters to deal with. A leaking sink can flood your cabinets, create mold and cause thousands of dollars of damage. I have prepared a relatively simple and inexpensive fix to repair a leaking garbage disposal without the hassle of calling a plumber and spending a larger amount of money. This fix requires a screw driver, a hammer or chisel and Plumber's Putty.
Unplug the garbage disposal from the power source.
Loosen and disconnect the dishwasher drain hose from the garbage disposal unit by loosening the clamp and removing the screws with a flathead screwdriver.
Pull the gray tube from the disposal.
Remove the three screws from the flange at the top of the garbage disposal unit. These screws are at the top right above the black disposal box.
Disconnect lock-nut at flange.
Use screwdriver to turn locking ring counter clock-wise disengaging drain hose and disposal.
Disposal will drop down. When disposal falls catch and place on bottom of sink.
Move from underneath the sink to the top of the sink.
To remove flange you will push from underneath the sink with one hand and pull it out through the top of the sink with your other hand.
Scrape off ALL excess putty from flange and sink.
Remove small ball of putty and roll into golf ball shape.
Roll flat until putty becomes snakelike shape approximately 3/4 inch diameter.
Roll into snake-like shape until long enough to fit fully around flange.
Wrap around flange and place flange back into sink.
Press down hard into sink and remove any excess Plumber's Putty.
Reassemble flange and garbage disposal reversing steps.
Put sink stopper in and fill up sink approximately halfway. Remove stopper and check underneath sink for leak.
