How to fix a leaking garbage disposal at flange
  1. How to fix a leaking garbage disposal at flange, How to fix a leaking garbage disposal at flange: step 1, image 1 of 2 How to fix a leaking garbage disposal at flange, How to fix a leaking garbage disposal at flange: step 1, image 2 of 2
    • Unplug the garbage disposal from the power source.
    • Be sure to place the wall plug in a dry location for the duration of the fix.
  2. How to fix a leaking garbage disposal at flange: step 2, image 1 of 2 How to fix a leaking garbage disposal at flange: step 2, image 2 of 2
    • Loosen and disconnect the dishwasher drain hose from the garbage disposal unit.
    • Do so by loosening the clamp and unscrewing the screws with a flathead screwdriver.
    • Remove the screws and pull the gray tube from the disposal.
  3. How to fix a leaking garbage disposal at flange: step 3, image 1 of 2 How to fix a leaking garbage disposal at flange: step 3, image 2 of 2
    • Remove the three screws from the flange at the top of the garbage disposal unit. These screws are at the top right above the black disposal box.
    • Disconnect lock-nut at flange.
    • Adequate lighting is imperative for this step.
  4. How to fix a leaking garbage disposal at flange: step 4, image 1 of 2 How to fix a leaking garbage disposal at flange: step 4, image 2 of 2
    • Use screwdriver to turn locking ring counter clock-wise disengaging drain hose and disposal.
    • You will be able to hear the locking ring come undone after pushing it forcefully to the left.
    • Disposal will drop down. When disposal falls catch and place on bottom of sink.
    • Move from underneath the sink to the top of the sink.
  5. How to fix a leaking garbage disposal at flange: step 5, image 1 of 2 How to fix a leaking garbage disposal at flange: step 5, image 2 of 2
    • To remove flange you will push from underneath the sink with one hand and pull it out through the top of the sink with your other hand.
    • Scrape off ALL excess putty from flange and sink.
  6. How to fix a leaking garbage disposal at flange: step 6, image 1 of 3 How to fix a leaking garbage disposal at flange: step 6, image 2 of 3 How to fix a leaking garbage disposal at flange: step 6, image 3 of 3
    • Remove small ball of putty and roll into golf ball shape.
    • Roll flat until putty becomes snakelike shape approximately 3/4 inch diameter.
    • Be sure that putty is long enough to wrap completely around flange.
  7. How to fix a leaking garbage disposal at flange: step 7, image 1 of 2 How to fix a leaking garbage disposal at flange: step 7, image 2 of 2
    • Roll into snake-like shape until long enough to fit fully around flange.
    • Wrap around flange and place flange back into sink.
    • Press down hard into sink and remove any excess Plumber's Putty.
  8. How to fix a leaking garbage disposal at flange: step 8, image 1 of 1
    • Reassemble flange and garbage disposal reversing steps.
    • Put sink stopper in and fill up sink approximately halfway. Remove stopper and check underneath sink for leak.
Amy Haren
175 Reputation
1 Guide authored
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 104
All Time: 6,301
