How to Fix a Hole In Drywall
    1. How to Fix a Hole In Drywall, How to Fix a Hole In Drywall: step 1, image 1 of 3 How to Fix a Hole In Drywall, How to Fix a Hole In Drywall: step 1, image 2 of 3 How to Fix a Hole In Drywall, How to Fix a Hole In Drywall: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Use pliers (or tweezers if the hole is very small) to clean out hole by removing the drywall out of the hole.
      Ask FixBot
    2. How to Fix a Hole In Drywall: step 2, image 1 of 1
      • Use scissors to cut drywall mesh.
      • To ensure that the entire hole is covered, cut a piece of mesh larger than the size of the hole.
      Ask FixBot
    3. How to Fix a Hole In Drywall: step 3, image 1 of 2 How to Fix a Hole In Drywall: step 3, image 2 of 2
      • Use a damp sponge to apply moisture to make the mesh stick to the wall, covering the entire hole.
      Ask FixBot
    4. How to Fix a Hole In Drywall: step 4, image 1 of 3 How to Fix a Hole In Drywall: step 4, image 2 of 3 How to Fix a Hole In Drywall: step 4, image 3 of 3
      • Use a drywall knife to apply the drywall compound over the mesh. Make sure to spread a generous amount over the entire mesh.
      • Let the compound dry for about 30 minutes.
      • You can speed up the drying process by placing a fan directly in front of the drying compound.
      Ask FixBot
    5. How to Fix a Hole In Drywall: step 5, image 1 of 1
      • Once compound is dry, use sandpaper to smooth out the entire surface of the dried compound.
      Ask FixBot
    6. How to Fix a Hole In Drywall: step 6, image 1 of 3 How to Fix a Hole In Drywall: step 6, image 2 of 3 How to Fix a Hole In Drywall: step 6, image 3 of 3
      • Paint over the surface with a paint brush.
      • Use paint that matches the rest of the wall for best results.
      Ask FixBot
10 other people completed this guide.
1 Guide Comment
Oi! como faço reboca que a parede está pintada branca?
dezinho anderson - Reply Share
Past 24 Hours: 15
Past 7 Days: 74
Past 30 Days: 322
All Time: 12,912
