Introduction
Engineers design car engines to operate at a set temperature. Maintaining this temperature is key, and without cooling, various internal engine components can overheat and fail catastrophically. A radiator helps to keep an engine within this operating temperature by cooling hot liquid from the engine. Clearly, a leaking radiator is of great concern and must be addressed. This guide will walk you through the application of K-Seal, a product designed to combat minor radiator leaks.
Pull up on the release lever to open the hood.
Underneath the Hyundai symbol in the front of the car, there will be a lever. Move the lever to the side to unlock the hood, then you should be able to lift the hood up.
Angle the hood prop into the hole on the underside of the car hood to keep it in place.
This is the coolant reservoir, which holds your cars coolant to keep the engine from overheating during use.
This is the radiator cap that is connected to the radiator. The cap itself regulates the pressure in the radiator to prevent overheating!
Take the cap off, pour the coolant into the tank then close the cap.
Slowly pour the entire K-Seal container into the radiator before closing the radiator cap.
