How to Fix a Broken Plastic Figurine
  1. How to Fix a Broken Plastic Figurine, How to Fix a Broken Plastic Figurine: step 1, image 1 of 2 How to Fix a Broken Plastic Figurine, How to Fix a Broken Plastic Figurine: step 1, image 2 of 2
    • Wipe down the figurine carefully with an alcohol wipe, focusing on the broken areas.
  2. How to Fix a Broken Plastic Figurine: step 2, image 1 of 3 How to Fix a Broken Plastic Figurine: step 2, image 2 of 3 How to Fix a Broken Plastic Figurine: step 2, image 3 of 3
    • Plug in the hot glue gun and let it heat up.
    • Do not directly touch the tip of the hot glue gun.
    • Straighten out the paperclip.
    • Place the paperclip in the tip of the hot glue gun in order to heat the metal.
    • Allow the paperclip to heat up for 5 minutes.
  3. How to Fix a Broken Plastic Figurine: step 3, image 1 of 1
    • Remove the paperclip from the glue gun.
    • Use the heated paperclip to scrape away excess material from one part of the figurine.
  4. How to Fix a Broken Plastic Figurine: step 4, image 1 of 1
    • Firmly press the glue gun's heated tip into the other part of the figurine to melt the surrounding plastic for smoother placement.
  5. How to Fix a Broken Plastic Figurine: step 5, image 1 of 2 How to Fix a Broken Plastic Figurine: step 5, image 2 of 2
    • Align the broken pieces together carefully.
    • Press the two pieces together.
    • Hold together tightly for a minute to bond the pieces.
  6. How to Fix a Broken Plastic Figurine: step 6, image 1 of 3 How to Fix a Broken Plastic Figurine: step 6, image 2 of 3 How to Fix a Broken Plastic Figurine: step 6, image 3 of 3
    • Apply tape to keep the pieces together.
    • Let it sit for 1 hour.
  7. How to Fix a Broken Plastic Figurine: step 7, image 1 of 2 How to Fix a Broken Plastic Figurine: step 7, image 2 of 2
    • Remove the tape top-down.
    • You're finished!
Finish Line
Jackson Smith
157 Reputation
1 Guide authored
UC Davis, Team 2-2, Vidal-Chiesa Fall 2024 Member of UC Davis, Team 2-2, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S2G2
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 78
All Time: 769
