How to Fix a Bent Rim on a Basketball Hoop
  1. How to Fix a Bent Rim on a Basketball Hoop, How to Fix a Bent Rim on a Basketball Hoop: step 1, image 1 of 2 How to Fix a Bent Rim on a Basketball Hoop, How to Fix a Bent Rim on a Basketball Hoop: step 1, image 2 of 2
    • Carefully examine the rim to determine the extent and location of the bend.
    • This will help you focus your efforts and decide if additional steps are needed.
  2. How to Fix a Bent Rim on a Basketball Hoop: step 2, image 1 of 1
    • If the net/mesh is still attached, consider removing it from the bent area or the entire rim.
    • This will give you better access to the damaged section and prevent any accidental damage to the net/mesh during the repair process.
  3. How to Fix a Bent Rim on a Basketball Hoop: step 3, image 1 of 1
    • Place a sturdy, flat piece of wood inside the rim.
    • This will distribute the pressure from the hydraulic jack evenly and protect the rim's inner surface.
  4. How to Fix a Bent Rim on a Basketball Hoop: step 4, image 1 of 1
    • Set the hydraulic jack on top of the wooden surface inside the rim. Adjust its position so that when extended, it will make contact with the bent area.
    • Check the jack for any leaks, cracks, or damage before each use.
    • Ensure the jack is placed on a firm, level surface. The base should be fully supported to prevent tipping.
  5. How to Fix a Bent Rim on a Basketball Hoop: step 5, image 1 of 1
    • Before the jack touches the bent area, place a piece of cardboard or cloth between the jack and the rim.
    • This will prevent scratches or other damage to the rim's finish.
    • Pump the jack slowly and steadily. This gives you better control and allows you to stop if you notice any instability.
  6. How to Fix a Bent Rim on a Basketball Hoop: step 6, image 1 of 1
    • Slowly extend the hydraulic jack until it makes contact with the protected bent area. Continue to apply pressure gradually, watching closely as the rim begins to straighten.
    • Be careful not to over-correct, as this may cause damage in the opposite direction.
  7. How to Fix a Bent Rim on a Basketball Hoop: step 7, image 1 of 1
    • If needed, use a pipe wrench to make minor adjustments. Wrap the wrench's jaws with cloth to protect the rim's finish. Apply gentle pressure to tweak any small bends or irregularities.
  8. How to Fix a Bent Rim on a Basketball Hoop: step 8, image 1 of 1
    • Carefully examine the rim from all angles to ensure it's properly straightened. If necessary, repeat steps 6-8 for any remaining bent areas.
With patience and the right tools, fixing a bent basketball rim is a manageable and easy DIY project. After straightening the rim, conduct a final inspection from all angles to ensure it's properly aligned. If you removed the net earlier, don't forget to reattach it to complete the repair. This method can restore your rim to its proper shape, saving you the cost of a replacement. Remember to work carefully and prioritize safety throughout the process. Once fixed, your rim should be ready for many more games and practice sessions. Regular inspections can help catch and address any future bends early, prolonging the life of your basketball hoop.
Ashwin
184 Reputation
1 Guide authored
1 Guide Comment
We did not have a hydraulic jack but used our car jack and it worked perfectly. Measured the rim in multiple directions to get it back to a circle. Thanks for the inspiration!
Dave - Reply Share
Past 24 Hours: 7
Past 7 Days: 43
Past 30 Days: 149
All Time: 1,805
