How to Fix Sticky Controls on a Logitech RumblePad2
  1. How to Fix Sticky Controls on a Logitech RumblePad2, How to Fix Sticky Controls on a Logitech RumblePad2: step 1, image 1 of 1
    • Remove the battery pack cover.
    • Remove the batteries.
  2. How to Fix Sticky Controls on a Logitech RumblePad2: step 2, image 1 of 1
    • Remove the five screws from the back of the controller using the #0 Phillips screwdriver.
  3. How to Fix Sticky Controls on a Logitech RumblePad2: step 3, image 1 of 2 How to Fix Sticky Controls on a Logitech RumblePad2: step 3, image 2 of 2
    • Remove the back panel from the controller.
    • It is easiest to first pry off the panel from the bottom, as shown in the pictures.
    • If using a tool to pry the panel off, do not insert the tool far into the controller. This may damage the motherboard.
  4. How to Fix Sticky Controls on a Logitech RumblePad2: step 4, image 1 of 1
    • Remove the two screws from the motherboard using the #0 Phillips screwdriver.
  5. How to Fix Sticky Controls on a Logitech RumblePad2: step 5, image 1 of 2 How to Fix Sticky Controls on a Logitech RumblePad2: step 5, image 2 of 2
    • Remove the rumble motors from their slots and allow them to hang freely.
    • Remove the motherboard from the controller by lifting up.
  6. How to Fix Sticky Controls on a Logitech RumblePad2: step 6, image 1 of 1
    • Wipe the outer face of the analog sticks with a wet cotton swab or paper towel.
  7. How to Fix Sticky Controls on a Logitech RumblePad2: step 7, image 1 of 1
    • Wipe the button pads with a wet cotton swab or paper towel.
  8. How to Fix Sticky Controls on a Logitech RumblePad2: step 8, image 1 of 2 How to Fix Sticky Controls on a Logitech RumblePad2: step 8, image 2 of 2
    • Remove the buttons from their slots by pushing them in from the front.
    • Wipe the buttons with a wet cotton swab or paper towel
After allowing the controller time to dry, reassemble your device by following these instructions in reverse order.
Dan Heckman
101 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 1,136
