How to Fix Plastic Chair Cracks
  1. How to Fix Plastic Chair Cracks, How to Fix Plastic Chair Cracks: step 1, image 1 of 2 How to Fix Plastic Chair Cracks, How to Fix Plastic Chair Cracks: step 1, image 2 of 2
    • Lay the broken chair such that the crack is parallel to the floor.
  2. How to Fix Plastic Chair Cracks: step 2, image 1 of 2 How to Fix Plastic Chair Cracks: step 2, image 2 of 2
    • Wear gloves to minimize chemical contact on skin.
    • Dampen a rag with isopropyl alcohol.
  3. How to Fix Plastic Chair Cracks: step 3, image 1 of 2 How to Fix Plastic Chair Cracks: step 3, image 2 of 2
    • Clean the surface of the crack with the dampened rag to remove all dust and debris.
    • Repeat on all sides of the crack (edges and backside).
  4. How to Fix Plastic Chair Cracks: step 4, image 1 of 3 How to Fix Plastic Chair Cracks: step 4, image 2 of 3 How to Fix Plastic Chair Cracks: step 4, image 3 of 3
    • Apply glue between the crack.
    • Then apply glue across the surface of the crack.
  5. How to Fix Plastic Chair Cracks: step 5, image 1 of 1
    • Hold the two glued pieces together for 30 seconds to allow the glue to bind to the chair.
    • Do not let the glue dry completely. The wet glue will need to bind with baking soda in the next step.
  6. How to Fix Plastic Chair Cracks: step 6, image 1 of 3 How to Fix Plastic Chair Cracks: step 6, image 2 of 3 How to Fix Plastic Chair Cracks: step 6, image 3 of 3
    • Pour baking soda over the crack until the glue is completely covered under a layer of baking soda.
  7. How to Fix Plastic Chair Cracks: step 7, image 1 of 2 How to Fix Plastic Chair Cracks: step 7, image 2 of 2
    • Use your finger to distribute the baking soda in order to cover all parts of the crack.
  8. How to Fix Plastic Chair Cracks: step 8, image 1 of 3 How to Fix Plastic Chair Cracks: step 8, image 2 of 3 How to Fix Plastic Chair Cracks: step 8, image 3 of 3
    • Allow the baking soda to seal onto the super glue over the crack and wait for the mixture to dry.
    • After ten minutes, brush away some of the un-glued baking soda to check if the glue is solid.
  9. How to Fix Plastic Chair Cracks: step 9, image 1 of 2 How to Fix Plastic Chair Cracks: step 9, image 2 of 2
    • Flip the chair over.
    • Repeat the procedure on the backside of the crack starting from step 4 and ending with step 8.
    • Avoid reapplying glue in between crack, since it has already been sealed.
  10. How to Fix Plastic Chair Cracks: step 10, image 1 of 2 How to Fix Plastic Chair Cracks: step 10, image 2 of 2
    • Remove excess baking soda from both the front and back side of the crack.
    • Use water or isopropyl alcohol to remove fine grains around the repair site.
  11. How to Fix Plastic Chair Cracks: step 11, image 1 of 1
    • Sand off any excess layers of glue on both the front and backside of the chair using coarse sandpaper.
    • This step is optional and simply helps to return the chair to its original look.
    • It may take a while to rid the chair of all texture.
  12. How to Fix Plastic Chair Cracks: step 12, image 1 of 1
    • The crack has been repaired!
Sumeet Dhillon
313 Reputation
1 Guide authored
UC Davis, Team S2-G7, Andersen Winter 2020 Member of UC Davis, Team S2-G7, Andersen Winter 2020
UCD-ANDERSEN-W20S2G7
3 Members
5 Guides authored
Past 24 Hours: 39
Past 7 Days: 223
Past 30 Days: 1,084
All Time: 43,992
