How to Fix PS4 Controller Analog Drift (R3 or L3 not working)
  1. How to Fix PS4 Controller Analog Drift (R3 or L3 not working), How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 1, image 1 of 2 How to Fix PS4 Controller Analog Drift (R3 or L3 not working), How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 1, image 2 of 2
    • Remove the four screws from the back of your controller using a Phillips #0 screwdriver.
    • Separate the front and the back of the controller.
  2. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 2, image 1 of 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 2, image 2 of 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 2, image 3 of 3
    • Unplug the ribbon cable to disconnect the Micro-USB Type B port from the controller itself.
    • Be careful not to tear or damage the cable.
  3. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 3, image 1 of 1
    • Unplug the battery from the controller and take it out.
    • Be careful not to tear or damage the wire as this is an important component for your controller.
  4. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 4, image 1 of 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 4, image 2 of 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 4, image 3 of 3
    • Remove the single screw from the black plate covering the motherboard using a Phillips #0 screwdriver.
    • Remove the black plate from the controller.
  5. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 5, image 1 of 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 5, image 2 of 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 5, image 3 of 3
    • Disconnect the ribbon cable that connects the back of the controller to the motherboard.
    • Remove the motherboard from the back of the controller.
    • Be careful not to tear or damage this wire as it is important for your controller.
  6. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 6, image 1 of 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 6, image 2 of 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 6, image 3 of 3
    • Remove the toggle sticks from the controller.
    • Be careful of the sensors as they are very sensitive.
  7. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 7, image 1 of 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 7, image 2 of 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 7, image 3 of 3
    • Use a spudger to pry open the toggle stick sensor.
    • Use a cotton swab with a little bit of rubbing alcohol to remove the grease and build-up from the sensor.
  8. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 8, image 1 of 2 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 8, image 2 of 2
    • To reassemble the controller, place the back cover onto the motherboard.
    • Slip the red wire through the controller cover and plug it in.
  9. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 9, image 1 of 2 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 9, image 2 of 2
    • Put the black plate back on top of the motherboard and screw it in.
    • Make sure the back of the controller and the motherboard are firmly connected.
  10. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 10, image 1 of 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 10, image 2 of 3 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 10, image 3 of 3
    • Plug the battery back in and put it in its place.
    • Plug the white wire back into the motherboard.
  11. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 11, image 1 of 2 How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 11, image 2 of 2
    • Connect the front cover and the back cover of the controller and screw the four screws back in.
  12. How to Fix PS4 Controller Analog Drift (R3 or L3 not working): step 12, image 1 of 1
    • You're all done.
Sabih Akram
1,642 Reputation
2 Guides authored
Past 24 Hours: 69
Past 7 Days: 469
Past 30 Days: 2,238
All Time: 61,768
