How to Fix Cracked Glassware with Food Safe Resin
  1. How to Fix Cracked Glassware with Food Safe Resin, How to Fix Cracked Glassware with Food Safe Resin: step 1, image 1 of 1
    • Lay a garbage bag out on your workstation and put on disposable gloves.
    • Using separate cups, measure the resin and hardener to an exact 1:1 ratio.
    • Always wear gloves and ensure your work area is well-ventilated while working with resin. You may also want to wear safety glasses to protect your eyes.
  2. How to Fix Cracked Glassware with Food Safe Resin: step 2, image 1 of 2 How to Fix Cracked Glassware with Food Safe Resin: step 2, image 2 of 2
    • Add the resin and hardener to a container or bowl to mix the solution.
    • Scrape the sides of the measuring cups to ensure that both liquids are fully incorporated.
  3. How to Fix Cracked Glassware with Food Safe Resin: step 3, image 1 of 1
    • Use the mixing stick to stir the resin and hardener for at least three minutes.
    • Scrape the sides and bottom while mixing.
  4. How to Fix Cracked Glassware with Food Safe Resin: step 4, image 1 of 2 How to Fix Cracked Glassware with Food Safe Resin: step 4, image 2 of 2
    • Dip one end of the Q-Tip into the resin mixture. Submerging is not necessary; ensure the tip is coated enough to cover the surface of the crack.
    • Apply the resin mixture to the affected area(s), covering the crack completely. Cover both the inside and outside of the crack if necessary.
    • Be careful of loose shards of glass.
  5. How to Fix Cracked Glassware with Food Safe Resin: step 5, image 1 of 1
    • Allow the resin to cure for at least eight hours.
  6. How to Fix Cracked Glassware with Food Safe Resin: step 6, image 1 of 2 How to Fix Cracked Glassware with Food Safe Resin: step 6, image 2 of 2
    • Place the Q-tip and leftover resin into a disposable, sealable plastic bag.
    • Allow it to cure for 8+ hours before disposing.
    • Do NOT pour resin down the drain or into the sink.
    • Flip the measuring and mixing cups over the trash bag to remove any excess resin or hardener.
  7. How to Fix Cracked Glassware with Food Safe Resin: step 7, image 1 of 2 How to Fix Cracked Glassware with Food Safe Resin: step 7, image 2 of 2
    • When the resin has finished curing, use an alcohol wipe to remove any excess from the surface of your glass item.
    • If the resin is too hard, use a craft blade to gently scrape off the excess.
    • Exercise caution when working with blades.
  8. How to Fix Cracked Glassware with Food Safe Resin: step 8, image 1 of 2 How to Fix Cracked Glassware with Food Safe Resin: step 8, image 2 of 2
    • Pour warm water to ensure that the glassware is heat-safe and that the cracks are completely sealed.
    • Wash the glassware gently and thoroughly to remove any excess resin applied on the inside.
Finish Line
Hana
181 Reputation
1 Guide authored
1 Guide Comment
After applying resin, can I heat the item in open flame source ?
Jaggermeister Asti - Reply
Past 24 Hours: 7
Past 7 Days: 40
Past 30 Days: 147
All Time: 1,284
