How to Fix Bent Eyeglasses
    1. How to Fix Bent Eyeglasses, How to Fix Bent Eyeglasses: step 1, image 1 of 2 How to Fix Bent Eyeglasses, How to Fix Bent Eyeglasses: step 1, image 2 of 2
      • Hold the temple and the end-piece of the eyeglasses together so that the screw-holes are aligned.
      • On a flat surface, carefully place the 1.4 mm slotted screw in the screw-hole.
      Ask FixBot
    2. How to Fix Bent Eyeglasses: step 2, image 1 of 1
      • Use an eyeglasses screwdriver to screw the two pieces back together.
      Ask FixBot
    3. How to Fix Bent Eyeglasses: step 3, image 1 of 2 How to Fix Bent Eyeglasses: step 3, image 2 of 2
      • On medium heat, blow a hairdryer onto the bent part of the glasses in order to make it more malleable.
      • Using too much heat or heating the glasses for too long can cause permanent damage to the lenses or frames.
      Ask FixBot
    4. How to Fix Bent Eyeglasses: step 4, image 1 of 2 How to Fix Bent Eyeglasses: step 4, image 2 of 2
      • Gently bend the heated up piece until it appears straight again.
      • Bend the glasses lightly as not to snap or disfigure them further.
      Ask FixBot
    5. How to Fix Bent Eyeglasses: step 5, image 1 of 1
      • Place the glasses on a flat surface. All four bottom points should be touching the ground.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 37
Past 30 Days: 167
All Time: 1,617
