How to Enlarge a Skirt Waistband
  1. How to Enlarge a Skirt Waistband, How to Enlarge a Skirt Waistband: step 1, image 1 of 1
    • Measure the waist band with a ruler or measuring tape.
    • Measure your waist.
    • Subtract the two measurements to determine how many inches you want to add on.
  2. How to Enlarge a Skirt Waistband: step 2, image 1 of 3 How to Enlarge a Skirt Waistband: step 2, image 2 of 3 How to Enlarge a Skirt Waistband: step 2, image 3 of 3
    • Measure roughly 2 inches below the waistband.
    • Mark a vertical line with a tailor's chalk, a white pencil, or pins.
    • Cut down to the end of the line.
  3. How to Enlarge a Skirt Waistband: step 3, image 1 of 3 How to Enlarge a Skirt Waistband: step 3, image 2 of 3 How to Enlarge a Skirt Waistband: step 3, image 3 of 3
    • Measure and mark the elastic to twice the length you want to add on.
    • Cut the elastic strip.
    • Then, cut that same strip at the halfway mark.
  4. How to Enlarge a Skirt Waistband: step 4, image 1 of 3 How to Enlarge a Skirt Waistband: step 4, image 2 of 3 How to Enlarge a Skirt Waistband: step 4, image 3 of 3
    • Overlap your elastic strips from step 3.
    • Depending on how many inches you are adding on, you may need to cut several strips.
    • Sew the strips together
    • Be cautious of where you place your fingers when dealing with sharp objects.
  5. How to Enlarge a Skirt Waistband: step 5, image 1 of 2 How to Enlarge a Skirt Waistband: step 5, image 2 of 2
    • Fold the elastic in half.
    • Cut at about a 60 degree angle (creating a triangle).
  6. How to Enlarge a Skirt Waistband: step 6, image 1 of 1
    • Turn the skirt inside out.
    • Sew the elastic triangle into the opening you cut in Step 2.
    • Try your new skirt on for size.
Finish Line
Nisha Sahota
133 Reputation
1 Guide authored
UC Davis, Team 4-7, Vidal-Chiesa Fall 2024 Member of UC Davis, Team 4-7, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G7
3 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 204
