How to Clean and Sharpen your Andis Hair Clippers
Video Overview
  1. How to Clean and Sharpen your Andis Hair Clippers, How to Clean and Sharpen your Andis Hair Clippers: step 1, image 1 of 1
    • Use a Phillips #0 screwdriver to loosen the set screws by turning them left.
    • Remove the blade from your clipper.
  2. How to Clean and Sharpen your Andis Hair Clippers: step 2, image 1 of 1
    • Take a fine hair brush and sweep it across the clipper base.
    • This will remove any hair debris.
  3. How to Clean and Sharpen your Andis Hair Clippers: step 3, image 1 of 1
    • Fully immerse and soak your blade in 90% isopropyl alcohol to remove any rust that might be present.
    • The blade should soak a minimum of 5 minutes.
  4. How to Clean and Sharpen your Andis Hair Clippers: step 4, image 1 of 1
    • Take a clean lint free towel and dry the blade.
    • While drying, rub the blade in all directions applying light pressure to remove residue and polish the blade.
  5. How to Clean and Sharpen your Andis Hair Clippers: step 5, image 1 of 1
    • Run your blade left and right in a horizontal direction across a Whetstone honing stone. First on the coarse side to sharpen the blade then on the finishing side to smooth out the blade.
  6. How to Clean and Sharpen your Andis Hair Clippers: step 6, image 1 of 1
    • Rinse the honing stone under water and rub the stone back and forth the same direction you used to sharpen your blade.
    • This will clean your stone and remove any debris.
  7. How to Clean and Sharpen your Andis Hair Clippers: step 7, image 1 of 1
    • Place your blades back into position and insert your set screws into the proper holes. Use a Phillips #0 screwdriver to secure the screws.
    • Be careful to line up your blades correctly.
  8. How to Clean and Sharpen your Andis Hair Clippers: step 8, image 1 of 1
    • Apply oil to the base of your blades before your first use.
    • Blades should be oiled after every 3 or 4 uses.
  9. How to Clean and Sharpen your Andis Hair Clippers: step 9, image 1 of 1
    • Your clippers are ready for use.
    • Plug them in to let them run for a few moments before your first use.
Now that your clippers are clean and sharp, they're ready to tackle any haircut with ease. Remember to oil them regularly and repeat this cleaning process every few haircuts to maintain optimal performance. Enjoy using your freshly sharpened clippers!
Anthony Pablo
337 Reputation
2 Guides authored
Anthony's Team Member of Anthony's Team
Community
1 Member
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 112
All Time: 1,126
