JBL Clip 3 Carabiner Clip Replacement
Views: 6.9K
View statistics:
Past 24 Hours:
6
Past 7 Days:
45
Past 30 Days:
160
All Time:
6,883
Comments: 6
6 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your JBL Clip 3 clip mechanism is no longer functioning, or has broken, the carabiner clip may require replacement.
This guide will show you the step by step process of replacing a carabiner clip for a JBL Clip 3. The process won’t be too difficult, requiring no special skills. Make sure to be careful when removing parts, because they can be fragile.
Tools
    1. JBL Clip 3 Carabiner Clip Replacement, Speaker Grill: step 1, image 1 of 2 JBL Clip 3 Carabiner Clip Replacement, Speaker Grill: step 1, image 2 of 2
      • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
      • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
      Ask FixBot
    1. JBL Clip 3 Carabiner Clip Replacement, Speaker Housing: step 2, image 1 of 2 JBL Clip 3 Carabiner Clip Replacement, Speaker Housing: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
      Ask FixBot
    2. JBL Clip 3 Carabiner Clip Replacement: step 3, image 1 of 1
      • Separate the speaker housing from the rest of the body.
      • This requires minimal force; they are not glued together.
      Ask FixBot
    3. JBL Clip 3 Carabiner Clip Replacement: step 4, image 1 of 2 JBL Clip 3 Carabiner Clip Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
      Ask FixBot
    1. JBL Clip 3 Carabiner Clip Replacement, Carabiner Clip: step 5, image 1 of 2 JBL Clip 3 Carabiner Clip Replacement, Carabiner Clip: step 5, image 2 of 2
      • Lift the metal carabiner clip from the speaker housing.
      • They are not glued together and should separate easily.
      • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
      Ask FixBot
2 other people completed this guide.
Tyler Molden
497 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 45
Past 30 Days: 160
All Time: 6,883
