How to Clean a Robotic Vacuum Cleaner
      • Turn off the vacuum and remove it from the charging dock.
      Ask FixBot
      • Open the dustbin compartment and remove the bin.
      • Dump all debris into the trash.
      • Remove the filter from the dustbin.
      • Rinse the dustbin if it's washable (check your model's manual)
      • Tap the filter gently to dislodge dust or use a nylon brush.
      • Replace the filter if it’s too dirty or damaged. Some filters are washable but still need replacement after a few washes.
      • Do not rinse the filter unless it's labeled washable.
      • Make sure that both filter and dustbin are completely dry before reinstalling to prevent mold.
      Ask FixBot
    1. Tool used on this step:
      Utility Scissors
      $5.59
      Buy
      • Remove the main roller brush from its housing.
      • Cut away tangled hair with scissors.
      • Avoid cutting into the bristles or otherwise damaging the brush.
      Ask FixBot
      • Unscrew or pull out side brushes if removable.
      • Wipe them with a damp cloth to remove buildup.
      • Check for bent or damaged bristles and replace the side brush if needed.
      Ask FixBot
    2. Tool used on this step:
      Microfiber Cleaning Cloths
      $3.99
      Buy
      Ask FixBot
    3. Tool used on this step:
      Metal Spudger
      $2.99
      Buy
      • Remove debris stuck around the wheels and caster.
      • Use a spudger to gently pry off the front caster wheel.
      • Pull out any hair or debris wrapped around the caster axle.
      • Spin them manually to check for smooth motion.
      • Avoid forcing parts—check your manual for disassembly.
      Ask FixBot
      • Reinsert the filter, brush, and dustbin securely.
      • Power on the vacuum and run a short cleaning cycle.
      • Listen for unusual sounds that could indicate issues.
      • Don’t run the vacuum if anything feels loose or jammed.
      Ask FixBot
Now that everything’s cleaned and reassembled, your vacuum is ready to get back to work.
Sebastian
33,675 Reputation
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 114
All Time: 535
