Philips TAS7505 Motherboard Replacement
    1. Philips TAS7505 Motherboard Replacement, Philips TAS7505 Outer Shell Disassembly: step 1, image 1 of 2 Philips TAS7505 Motherboard Replacement, Philips TAS7505 Outer Shell Disassembly: step 1, image 2 of 2
      • Make sure the speaker is turned off before you begin the disassembly.
      • Turn the speaker upside down. You will see a rubber base. Use an opening tool to lift up the sides to expose the screws.
      Ask FixBot
    2. Philips TAS7505 Motherboard Replacement: step 2, image 1 of 3 Philips TAS7505 Motherboard Replacement: step 2, image 2 of 3 Philips TAS7505 Motherboard Replacement: step 2, image 3 of 3
      • There will be 4 exposed screws. Make sure to use the Phillips #0 Screwdriver.
      • When the screws are removed, you can use an opening tool to take off the plastic cover.
      Ask FixBot
    3. Philips TAS7505 Motherboard Replacement: step 3, image 1 of 3 Philips TAS7505 Motherboard Replacement: step 3, image 2 of 3 Philips TAS7505 Motherboard Replacement: step 3, image 3 of 3
      • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with a Philips #0 screwdriver.
      • Once all these screws are removed, you can take off the cover
      Ask FixBot
    4. Philips TAS7505 Motherboard Replacement: step 4, image 1 of 3 Philips TAS7505 Motherboard Replacement: step 4, image 2 of 3 Philips TAS7505 Motherboard Replacement: step 4, image 3 of 3
      • You can now see the inside of the speaker but you aren't done yet.
      • Remove both rubber stands that hold up the device horizontally (one of these stands is a cover for the USB ports).
      Ask FixBot
    5. Philips TAS7505 Motherboard Replacement: step 5, image 1 of 1
      • Once you pull these out, you can pull the whole sleeve to expose the infrastructure of the device.
      Ask FixBot
    1. Philips TAS7505 Motherboard Replacement, Motherboard: step 6, image 1 of 3 Philips TAS7505 Motherboard Replacement, Motherboard: step 6, image 2 of 3 Philips TAS7505 Motherboard Replacement, Motherboard: step 6, image 3 of 3
      • Disconnect the battery from the motherboard by unclipping it from the side not visible to you
      • If you are having difficulties disconnecting the battery you can pull the battery out whole in order to get a better angle to disconnect it
      Ask FixBot
    2. Philips TAS7505 Motherboard Replacement: step 7, image 1 of 1
      • Pull out the motherboard then disconnect the USB-A & USB-C port by pressing the clip
      Ask FixBot
    3. Philips TAS7505 Motherboard Replacement: step 8, image 1 of 2 Philips TAS7505 Motherboard Replacement: step 8, image 2 of 2
      • Next is to disconnect the speaker
      • pull the motherboard out as much as you can and then wiggle the white box back and forth to get it out
      Ask FixBot
    4. Philips TAS7505 Motherboard Replacement: step 9, image 1 of 2 Philips TAS7505 Motherboard Replacement: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Simply remove this white strand with a pair of tweezers.
      Ask FixBot
    5. Philips TAS7505 Motherboard Replacement: step 10, image 1 of 2 Philips TAS7505 Motherboard Replacement: step 10, image 2 of 2
      • This is how the motherboard should be after doing all the steps correctly.
      Ask FixBot
Alejandro
133 Reputation
1 Guide authored
CSU Los Angeles, Team 5-2, Adachi Fall 2022 Member of CSU Los Angeles, Team 5-2, Adachi Fall 2022
CSULA-ADACHI-F22S5G2
5 Members
60 Guides authored
1 Guide Comment
The guides are very detailed with many steps and are easy to follow. It looks professional and well-made. Thank you for your contribution to Ifixit!
Dat Nguyen - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 26
All Time: 851
