Insignia NS-F12R6-SS Upper Oscillation Gear Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
67
All Time:
1,141
Comments: 5
5 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The oscillation gear swivels the head of the fan back and forth by translating power from the motor into the oscillation arm.
    1. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Front Cage: step 1, image 1 of 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Front Cage: step 1, image 2 of 2
      • Unplug your fan.
      • Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
      Ask FixBot
    2. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 2, image 1 of 1
      • Remove the ring that runs around the edge of the fan cage.
      Ask FixBot
    3. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 3, image 1 of 1
      • Remove the front of the fan cage.
      Ask FixBot
    1. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Fan Blade: step 4, image 1 of 1
      • Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
      Ask FixBot
    2. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 5, image 1 of 1
      • Take caution when removing the fan blades. They can be sharp!
      • Slide the fan blade off the end of the rotor.
      Ask FixBot
    1. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Back Cage: step 6, image 1 of 1
      • Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
      Ask FixBot
    2. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 7, image 1 of 1
      • Pull the back cage off.
      Ask FixBot
    1. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Oscillation Button: step 8, image 1 of 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Oscillation Button: step 8, image 2 of 2
      • Unscrew the 10 mm screw in the center hole of the oscillation knob with a Phillips #3 screwdriver.
      Ask FixBot
    2. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 9, image 1 of 1
      • Remove the oscillation knob.
      Ask FixBot
    1. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Motor Housing: step 10, image 1 of 1
      • Use your fingers to gently pull the power knob directly away from the motor housing.
      Ask FixBot
    2. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 11, image 1 of 1
      • Unscrew the flat 17 mm nut fastened at the bottom of the power knob with a small crescent wrench.
      Ask FixBot
    3. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 12, image 1 of 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 12, image 2 of 2
      • Remove the four 6 mm bolts and small washers that secure the front face of the motor housing with a Phillips #3 screwdriver and remove the washers.
      Ask FixBot
    4. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 13, image 1 of 1
      • Pull the front face of the motor housing off toward the front of the rotor.
      Ask FixBot
    5. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 14, image 1 of 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 14, image 2 of 2
      • Remove the 10 mm triangular-headed bolt with a Phillips #3 screwdriver.
      Ask FixBot
    6. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 15, image 1 of 1
      • Slide the back end of the motor housing away from the front of the rotor.
      Ask FixBot
    7. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 16, image 1 of 1
      • Remove the small piece of paper hanging on the power button.
      Ask FixBot
    1. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Upper Oscillation Gear: step 17, image 1 of 3 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Upper Oscillation Gear: step 17, image 2 of 3 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement, Upper Oscillation Gear: step 17, image 3 of 3
      • Using a Phillips #3 screwdriver, unscrew and remove the 7 mm long bolt and small washer fastening the yellow and green wire to the motor housing support.
      Ask FixBot
    2. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 18, image 1 of 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 18, image 2 of 2
      • Using a Phillips #3 screwdriver unscrew the 13 mm long screw fastening the motor housing support to the oscillation gear box.
      Ask FixBot
    3. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 19, image 1 of 3 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 19, image 2 of 3 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 19, image 3 of 3
      • Using a Phillips #3 screwdriver, unscrew the three 13 mm long screws fastening the grey plate to the top of the oscillation gear box.
      • Remove the grey cap covering the oscillation gear box.
      Ask FixBot
    4. Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 20, image 1 of 2 Insignia NS-F12R6-SS Upper Oscillation Gear Replacement: step 20, image 2 of 2
      • Remove the upper oscillation gear.
      Ask FixBot
Hank
1,142 Reputation
8 Guides authored
CSU Fullerton, Team S2-G1, Bruce Fall 2018 Member of CSU Fullerton, Team S2-G1, Bruce Fall 2018
CSUF-BRUCE-F18S2G1
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 67
All Time: 1,141
