Up to 20% off select tools
How to Clean a Beko Washing Machine
View statistics:
Past 24 Hours:
3
Past 7 Days:
44
Past 30 Days:
162
All Time:
787
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 hours
Difficulty: Moderate
Video Guide
This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓
Clean the dispenser drawer, pump filter, door seal, and drum on a Beko front-loading washing machine to keep it clean and odor-free. This routine helps remove detergent residue, mold, and bacteria that can cause bad smells, especially if you mostly wash at 30 °C or 40 °C. The door seal is also called the door seal or door gasket. This guide was written using a Beko WN622W, but other Beko front-loading washers are similar and may have small control differences.
      • Run this cleaning routine every 30 washing cycles or every couple of months.
      • Clean the washer more often if most loads use 30 °C or 40 °C, because those temperatures aren't hot enough to kill bacteria and odor-causing residue.
      • Unplug the washer before cleaning the filter, drawer, or door seal.
      • Wear rubber gloves and follow the cleaner label before handling detergent, cleaner, or filter debris.
      • Gather a brush, hot, soapy water, a wet cloth, a towel, a shallow container, and a washing machine cleaner.
      Ask FixBot
      • Clean the pump filter before working on the drawer and drum seal.
      • Keep a towel and a shallow container under the filter area to catch any trapped water.
      • Remove the pump filter, clean away trapped debris, and reinstall it securely.
      • Plug the washer back in only after the filter is fully closed.
      Ask FixBot
      • Pull the dispenser drawer out until it stops.
      • Press down the release button inside the drawer.
      • Pull the dispenser drawer out of the washer.
      Ask FixBot
      • Scrub the drawer with a brush and hot, soapy water.
      • Remove mold, residue, and detergent residue from every compartment.
      • Keep cleaning until the drawer is clean and free of residue.
      • Residue left in the drawer can wash into the laundry.
      Ask FixBot
      • Wipe the inside of the dispenser housing with a wet cloth and hot, soapy water.
      • Use a wire or a dental floss brush to clear the small jet holes if residue remains.
      • Cover the lower opening with the wet cloth so the brush or wire can't fall inside.
      • Slide the clean dispenser drawer back into the housing.
      Ask FixBot
      • Open the door and wipe the door seal with the wet cloth and hot, soapy water.
      • Clean around the visible rubber until mold, residue, and residue are gone.
      • Don't use sharp tools on the rubber seal, because punctures can cause leaks.
      Ask FixBot
      • Make sure the drum is empty.
      • Pour one dose of washing machine cleaner straight into the drum.
      • If you don't have washing machine cleaner, add a small amount of normal liquid detergent or washing powder instead.
      Ask FixBot
      • Select Drum Clean or Service Wash if the washer has that program.
      • If it doesn't, select a cotton wash, set it to the hottest temperature available, and choose Quick Wash.
      • On the Beko WN622W, the hottest cotton setting is 90 °C.
      • Press the Start button.
      Ask FixBot
      • Keep young children away while the cycle runs.
      • The water may reach 90 °C, and the door glass can get extremely hot.
      • Let the washer complete the rinse and final spin.
      • A cotton 90 °C quick cycle takes about an hour and a half on this model.
      • The hot cycle helps reduce odor-causing residue and leaves the washer clean and odor-free.
      Ask FixBot
      • When the program ends, turn the washer off and open the door.
      • Check that the drum smells fresh.
      • Leave the dispenser drawer and door open if the washer will sit unused for a while.
      • Ventilation helps the washer dry and slows odor buildup.
      Ask FixBot
      • If the washer still smells after cleaning, check the pump filter and drainage hose for a blockage.
      • If the washer isn't draining water, clear the blocked drain before running another cleaning cycle.
      • Repeat the hygiene cleaning routine every 30 washing cycles or every couple of months.
      Ask FixBot
Keep the door and dispenser drawer open after cleaning if the washer will sit unused, and repeat the routine every 30 cycles or every couple of months. If odors remain, check for a blocked pump filter or drainage hose before running another hot cleaning cycle. Repair didn't go as planned? Ask our Answers community for help.
Author
with
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 44
Past 30 Days: 162
All Time: 787
