Sony Bloggie 3D Player Back Cover Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
10
Past 30 Days:
34
All Time:
823
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will detail the steps necessary to remove the back cover of the Sony Bloggie 3D Player.
Tools
    1. Sony Bloggie 3D Player Back Cover Replacement, Front Cover: step 1, image 1 of 1
      • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
      Ask FixBot
    2. Sony Bloggie 3D Player Back Cover Replacement: step 2, image 1 of 2 Sony Bloggie 3D Player Back Cover Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to pry the cover open.
      • After the the cover is partly open as shown, remove the cover with your hands.
      Ask FixBot
    1. Sony Bloggie 3D Player Back Cover Replacement, Back Cover: step 3, image 1 of 2 Sony Bloggie 3D Player Back Cover Replacement, Back Cover: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
      Ask FixBot
    2. Sony Bloggie 3D Player Back Cover Replacement: step 4, image 1 of 2 Sony Bloggie 3D Player Back Cover Replacement: step 4, image 2 of 2
      • Use a plastic opening tool to loosen the back cover off the device.
      • Once the back cover is loose, remove it gently by hand.
      Ask FixBot
Timothy Tran
1 Reputation
2 Guides authored
Cal Poly, Team 7-12, Maness Winter 2013 Member of Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 34
All Time: 823
