D-Link EBR-2310 Motherboard Replacement
    1. D-Link EBR-2310 Motherboard Replacement, Remove Plastic Screw Coverings: step 1, image 1 of 1
      • Begin by placing the wired router face down.
      • Locate the two black plastic screw coverings at the top of the device and remove them with your fingers.
      • The two bottom plastic screw coverings do not need to be taken off.
      Ask FixBot
    2. D-Link EBR-2310 Motherboard Replacement, Remove Screws: step 2, image 1 of 1
      • Using a Phillips #2 screwdriver, remove the two top screws.
      Ask FixBot
    3. D-Link EBR-2310 Motherboard Replacement, Pry Open The Router: step 3, image 1 of 1
      • Use a plastic opening tool between the edges of the router and gently pry the device apart.
      • Release the clips as you work your way around the device to avoid breaking them.
      • Separate the front and back case of the router.
      Ask FixBot
    4. D-Link EBR-2310 Motherboard Replacement, Remove Silver Casing: step 4, image 1 of 2 D-Link EBR-2310 Motherboard Replacement, Remove Silver Casing: step 4, image 2 of 2
      • Once you have removed the top black case of the router, remove the silver casing surrounding the logic board.
      • It should easily snap out of place.
      Ask FixBot
    5. D-Link EBR-2310 Motherboard Replacement, Remove Inner Bottom Screws: step 5, image 1 of 2 D-Link EBR-2310 Motherboard Replacement, Remove Inner Bottom Screws: step 5, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the two screws at the bottom of the motherboard.
      Ask FixBot
    6. D-Link EBR-2310 Motherboard Replacement, Remove Bottom Case: step 6, image 1 of 1
      • Now that you have removed all screws and the surrounding silver casing, pop the logic board out from the bottom component of the router.
      • You have now removed the logic board from your device.
      Ask FixBot
Jessica
428 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 25
All Time: 1,261
