Introduction
Go to step 1 ↓This guide will show you how to replace the I/O Cover on the Nikon Coolpix A900.
The I/O cover may need to be replaced due to normal wear and tear. Because it is a silicon part, it is prone to ripping after heavy periods of use.
You may not need the spudger listed in the tool section as it is possible to do it with just your fingers.
Tools
Orient the camera upside down, with the lens facing away from you.
Remove the two 3mm Phillips #00 screws from the right.
Remove the two 3.4mm Phillips #00 screws from the left.
Locate the I/O cover on the rear case.
On the inside of the case, unhook the I/O cover by lifting up.
