LG VX4400 Removing the Back Cover
Views: 3.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
39
All Time:
3,077
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. LG VX4400 Removing the Back Cover, Battery: step 1, image 1 of 3 LG VX4400 Removing the Back Cover, Battery: step 1, image 2 of 3 LG VX4400 Removing the Back Cover, Battery: step 1, image 3 of 3
      • Press the light grey button in the top-center on the back of the phone.
      • While pressing, slide the battery and cover up.
      Ask FixBot
    1. LG VX4400 Removing the Back Cover, Antenna: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Unscrew the antenna by grasping the base and twisting counterclockwise.
      • The antenna may separate from a black sleeve during removal. You may need to use tweezers to remove the sleeve. Remove both the antenna and the sleeve and set aside.
      Ask FixBot
    1. LG VX4400 Removing the Back Cover, LG VX4400 Removing the Back Cover: step 3, image 1 of 3 LG VX4400 Removing the Back Cover, LG VX4400 Removing the Back Cover: step 3, image 2 of 3 LG VX4400 Removing the Back Cover, LG VX4400 Removing the Back Cover: step 3, image 3 of 3
      • The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside.
      Ask FixBot
    2. LG VX4400 Removing the Back Cover: step 4, image 1 of 2 LG VX4400 Removing the Back Cover: step 4, image 2 of 2
      • Use a Torx T6 screwdriver to unscrew the four screws on the back of the phone.
      • The bit size is engraved on the base of the bit head.
      Ask FixBot
    3. LG VX4400 Removing the Back Cover: step 5, image 1 of 3 LG VX4400 Removing the Back Cover: step 5, image 2 of 3 LG VX4400 Removing the Back Cover: step 5, image 3 of 3
      • With the phone flipped open, wedge the back cover from the faceplate by running the tip of the plastic opening tool around the seam on the back of the phone.
      • Gently pull the two pieces apart to separate, and set the back casing aside.
      • Apply enough force to separate the pieces without cracking the back cover.
      Ask FixBot
    4. LG VX4400 Removing the Back Cover: step 6, image 1 of 1
      • Lift the motherboard to gain access to the keypad and side buttons beneath.
      • The motherboard is attached with a thin ribbon cable at the upper right corner of the case. Be careful not to break the cable.
      Ask FixBot
<b>To reassemble your device, follow these instructions in reverse order.</b>
Nico Chiarito
22 Reputation
5 Guides authored
Cal Poly, Team 8-47, Regan Winter 2010 Member of Cal Poly, Team 8-47, Regan Winter 2010
CPSU-REGAN-W10S8G47
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 39
All Time: 3,077
