How to Check a Car's Tire Pressure
  1. How to Check a Car's Tire Pressure, How to Check a Car's Tire Pressure: step 1, image 1 of 2 How to Check a Car's Tire Pressure, How to Check a Car's Tire Pressure: step 1, image 2 of 2
    • Your car's tire pressure information is likely located inside the car door frame toward the bottom.
    • You can also look up this information in your vehicle's owner's manual.
    • Do not refer to the tire pressure information printed on the tire itself! This displays the maximum tire pressure allowed, rather than the recommended level.
  2. How to Check a Car's Tire Pressure: step 2, image 1 of 3 How to Check a Car's Tire Pressure: step 2, image 2 of 3 How to Check a Car's Tire Pressure: step 2, image 3 of 3
    • Each tire has a valve stem located on the outer part of the wheel that sticks out.
    • Remove the cap by twisting it counter-clockwise and set it off to the side.
    • The cap is very small, so be sure to keep track of it!
  3. How to Check a Car's Tire Pressure: step 3, image 1 of 2 How to Check a Car's Tire Pressure: step 3, image 2 of 2
    • Place the stem of the tire pressure gauge onto the tire's valve stem and push on it with a decent amount of force.
    • You'll hear a brief hissing noise as the valve stem quickly opens and closes. If the noise continues, you likely aren't pressing down hard enough.
    • After a second or two, remove the tire pressure gauge. Again, you'll hear a brief hissing noise.
  4. How to Check a Car's Tire Pressure: step 4, image 1 of 2 How to Check a Car's Tire Pressure: step 4, image 2 of 2
    • Check the gauge to see what the tire pressure is. If it's low, add air to the tire until the gauge reads the proper tire pressure.
    • To reset the gauge to zero, press down on the gauge's bleeder valve.
Craig Lloyd
35,623 Reputation
82 Guides authored
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 54
All Time: 1,933
