Mercedes W123 Power Steering Fluid and Filter Change
  1. Mercedes W123 Power Steering Fluid and Filter Change, Mercedes W123 Power Steering Fluid and Filter Change: step 1, image 1 of 1
    • Jack up the front of the car so you can turn the steering wheel while the car is stationary.
    • [invalid guide link], if you need guidance on this.
  2. Mercedes W123 Power Steering Fluid and Filter Change: step 2, image 1 of 3 Mercedes W123 Power Steering Fluid and Filter Change: step 2, image 2 of 3 Mercedes W123 Power Steering Fluid and Filter Change: step 2, image 3 of 3
  3. Mercedes W123 Power Steering Fluid and Filter Change: step 3, image 1 of 1
    • With the lid removed you can see that this fluid is a bit low, and is also very dark/dirty.
  4. Mercedes W123 Power Steering Fluid and Filter Change: step 4, image 1 of 2 Mercedes W123 Power Steering Fluid and Filter Change: step 4, image 2 of 2
    • Remove the nut holding down the spring and plastic retainer, if present. On some cars, there is just a spring as shown in the second picture which should be removed.
    • The nut on this car is a 10mm.
  5. Mercedes W123 Power Steering Fluid and Filter Change: step 5, image 1 of 1
    • Now use your fluid extractor, or turkey baster (never use it in the kitchen again!) to remove enough fluid to get easy access to the filter.
    • Dispose of the fluid in your drain pan.
  6. Mercedes W123 Power Steering Fluid and Filter Change: step 6, image 1 of 1
    • Remove the filter using a pair of needle nose pliers.
  7. Mercedes W123 Power Steering Fluid and Filter Change: step 7, image 1 of 3 Mercedes W123 Power Steering Fluid and Filter Change: step 7, image 2 of 3 Mercedes W123 Power Steering Fluid and Filter Change: step 7, image 3 of 3
    • See how nasty this is? This may be the original filter, almost 30 years old...
    • Nice fresh filter picture, ready for install.
  8. Mercedes W123 Power Steering Fluid and Filter Change: step 8, image 1 of 1
    • With the filter out, you can remove the remainder of the fluid in the reservoir.
  9. Mercedes W123 Power Steering Fluid and Filter Change: step 9, image 1 of 1
    • Install your new filter. Install it with the holes facing upwards, as shown.
  10. Mercedes W123 Power Steering Fluid and Filter Change: step 10, image 1 of 1
    • Replace the spring, retainer and nut over the filter and tighten down. The spring should still have some room to expand and contract but should be snug.
    • Fill the reservoir to the bottom of the metal rim around the top of the pump housing.
    • This car is getting power steering fluid, instead of automatic transmission fluid. Both are OK. The power steering fluid is clear.
    • Now, turn on the engine. Be sure the car is in park or neutral first. Turn the steering wheel left and right, as far as it will go, a few times to get out any air.
    • Top off the fluid as needed. Never let the pump run dry.
    • If your fluid is very dirty, simply repeat the process of sucking out fluid, putting the filter back in, filling the reservoir, and then running the engine and turning the wheel until it looks clean.
Nicolas Siemsen
39,040 Reputation
79 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,539 Guides authored
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 147
All Time: 24,817
