How to Balance a Wobbly Ceiling Fan
    1. How to Balance a Wobbly Ceiling Fan, How to Balance a Wobbly Ceiling Fan: step 1, image 1 of 3 How to Balance a Wobbly Ceiling Fan, How to Balance a Wobbly Ceiling Fan: step 1, image 2 of 3 How to Balance a Wobbly Ceiling Fan, How to Balance a Wobbly Ceiling Fan: step 1, image 3 of 3
      • Place a ladder or step stool beneath the ceiling fan so you can safely reach above the fan blades.
      • Tighten the screws on the bottom of the downrod, turn it hand tight.
      • If there is a cover (like on this fan) you may have to lift it up to access the screws.
      Ask FixBot
    2. How to Balance a Wobbly Ceiling Fan: step 2, image 1 of 3 How to Balance a Wobbly Ceiling Fan: step 2, image 2 of 3 How to Balance a Wobbly Ceiling Fan: step 2, image 3 of 3
      • If you can access and tighten the fan blade screws without taking off the light kit, skip this step.
      • Make sure there is no power to the fan before doing this step.
      • Unscrew the light kit screws.
      • Make sure you are holding the light kit so it doesn't fall.
      • Disconnect the light kit and put it somewhere safe.
      Ask FixBot
    3. How to Balance a Wobbly Ceiling Fan: step 3, image 1 of 2 How to Balance a Wobbly Ceiling Fan: step 3, image 2 of 2
      • Insert a screwdriver through the opening and tighten each fan blade screw.
      • Do not overtighten the screws.
      • Rotate the fan blades with your hand to access and tighten the other blade screws.
      Ask FixBot
    4. How to Balance a Wobbly Ceiling Fan: step 4, image 1 of 2 How to Balance a Wobbly Ceiling Fan: step 4, image 2 of 2
      • Reconnect the light kit wire connection.
      • Screw the light kit back on firmly.
      Ask FixBot
    5. How to Balance a Wobbly Ceiling Fan: step 5, image 1 of 1
      • Turn the fan on.
      • If it isn't balanced to your liking, you will need to use a balancing kit.
      • Note which fan speed creates the most noticeable wobble, usually the highest setting.
      Ask FixBot
    6. How to Balance a Wobbly Ceiling Fan: step 6, image 1 of 2 How to Balance a Wobbly Ceiling Fan: step 6, image 2 of 2
      • Place a clip from the balancing kit in the middle of a random blade and turn the fan on. Take note of the difference in wobble.
      • Move the clip to the next blade over and turn the fan on again. Continue this process until you've tried the clip on each blade and found the one that improves the wobble the most.
      • For now, we are just putting the clip in the middle of the blades.
      Ask FixBot
    7. How to Balance a Wobbly Ceiling Fan: step 7, image 1 of 3 How to Balance a Wobbly Ceiling Fan: step 7, image 2 of 3 How to Balance a Wobbly Ceiling Fan: step 7, image 3 of 3
      • On the fan blade where the clip improves the wobble the most, move the clip slightly left or right.
      • Turn on the fan and repeat this process until you find the “sweet spot” where the wobble is minimized.
      Ask FixBot
    8. How to Balance a Wobbly Ceiling Fan: step 8, image 1 of 2 How to Balance a Wobbly Ceiling Fan: step 8, image 2 of 2
      • Put a couple droplets of superglue on the weight.
      • Balancing weights come with an adhesive built-in that you can use instead, superglue is just my recommendation.
      Ask FixBot
    9. How to Balance a Wobbly Ceiling Fan: step 9, image 1 of 2 How to Balance a Wobbly Ceiling Fan: step 9, image 2 of 2
      • If there is a lot of dust on the blade, wipe it off first to help the weight stick properly.
      • Place the weight with the superglue right in front of the clip.
      • Take the balancing clip off and allow a few minutes for the glue/adhesive to dry.
      Ask FixBot
    10. How to Balance a Wobbly Ceiling Fan: step 10, image 1 of 1
      • If the fan still isn't balanced to your liking, do the same process from step 6 starting on the next blade over.
      • Both weights may end up being on the same blade.
      Ask FixBot
    11. How to Balance a Wobbly Ceiling Fan: step 11, image 1 of 1
      • Your fan should be balanced!
      • If the wobble is still bad, the fan motor itself may have an issue or the electrical box in the attic may need to be tightened by a competent person.
      Ask FixBot
If the fan isn't balanced to your liking, you may want to try another balancing weight. If that doesn't work, there may be an issue with the fan motor itself, or the electrical box in the attic may need to be tightened by an expert.
Cameron Soto
193 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 17
All Time: 34
