How to Apply Silicone Electrical Tape
  1. How to Apply Silicone Electrical Tape, Prepare the work surface: step 1, image 1 of 1
    • The next four steps show how to use the silicone electrical tape to insulate a wire splice.
    • Clean your work surface and your hands before applying the silicone electrical tape.
  2. How to Apply Silicone Electrical Tape, Snip off a piece of tape: step 2, image 1 of 1
    Tool used on this step:
    $3.99
    Buy
    • Use scissors to cut off a small strip of silicone electrical tape.
    • Silicone electrical tape stretches several times its original length, so a short strip can cover more wire than you expect.
    • If you don't think you need a whole roll, check out our precut strips for small jobs or splicing on the go!
  3. How to Apply Silicone Electrical Tape, Remove part of the liner: step 3, image 1 of 3 How to Apply Silicone Electrical Tape, Remove part of the liner: step 3, image 2 of 3 How to Apply Silicone Electrical Tape, Remove part of the liner: step 3, image 3 of 3
    • Remove an inch or two of the plastic liner before before wrapping the silicone electrical tape.
    • The more the tape is stretched, the stronger and faster it will bond!
  4. How to Apply Silicone Electrical Tape, Apply the tape: step 4, image 1 of 3 How to Apply Silicone Electrical Tape, Apply the tape: step 4, image 2 of 3 How to Apply Silicone Electrical Tape, Apply the tape: step 4, image 3 of 3
    • Wrap a corner of the silicone electrical tape to one side of the exposed section of wire.
    • The wrap should extend an inch past the exposed portion of wire on both sides to ensure complete insulation.
    • Continue to wrap the tape around the wire while stretching the tape and removing the liner.
    • Overlap each layer by approximately 2/3 of the previous wrap for best results.
  5. How to Apply Silicone Electrical Tape, Finish the application: step 5, image 1 of 2 How to Apply Silicone Electrical Tape, Finish the application: step 5, image 2 of 2
    • Finish the application by completely overlapping the final wrap back on itself.
    • Press down firmly on the end to set the silicone electrical tape.
  6. How to Apply Silicone Electrical Tape, How to create a grippy surface: step 6, image 1 of 3 How to Apply Silicone Electrical Tape, How to create a grippy surface: step 6, image 2 of 3 How to Apply Silicone Electrical Tape, How to create a grippy surface: step 6, image 3 of 3
    • The next three steps show how to use the tape to create a grippy surface.
    • Clean the surface and your hands before applying the silicone electrical tape.
    • Press the end of the silicone electrical tape firmly on the handle.
    • While stretching the tape, completely overlap the first wrap on itself to ensure a good bond.
    • Continue to wrap the tape around the handle while stretching the tape and removing the liner.
  7. How to Apply Silicone Electrical Tape: step 7, image 1 of 2 How to Apply Silicone Electrical Tape: step 7, image 2 of 2
    • Use scissors to cut the silicone electrical tape, leaving a small strip to finish wrapping the handle.
    • Remove the liner completely.
  8. How to Apply Silicone Electrical Tape, Finish the wrap: step 8, image 1 of 3 How to Apply Silicone Electrical Tape, Finish the wrap: step 8, image 2 of 3 How to Apply Silicone Electrical Tape, Finish the wrap: step 8, image 3 of 3
Finish Line
2 other people completed this guide.
Robert Boyd
31,559 Reputation
94 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 35
Past 30 Days: 181
All Time: 1,386
