In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Community-Contributed Guide
Introduction
Go to step 1 ↓Use this guide to regularly clean, lubricate, and inspect your electric razor or trimmer. Routine maintenance keeps them cutting smoothly and helps prevent skin irritation. Always disconnect from power before starting. This approach extends their lifespan and supports sustainable practices in line with circular economy principles.
Step 1 Disconnect power and gather supplies
Have a cleaning brush, isopropyl alcohol, and machine oil ready for servicing.
Step 2 Remove and inspect the cutting elements
Take off the foil or blade assembly from the razor or trimmer as indicated by the manufacturer.
Step 3 Clean and brush away debris
Use a small brush or included cleaning tool to remove hair from the blades and housing.
Step 4 Soak the blades in alcohol
Place the blade and any removable parts in a container of isopropyl alcohol to disinfect and dissolve residue.
Shift the moving parts gently by hand to help dislodge any trapped hair or debris.
Allow these components to dry completely before reassembly.
Step 5 Lubricate the blades and moving parts
Place one or two drops of machine oil onto the moving parts and blade edges.
Activate the device briefly after reassembly to spread the lubricant evenly.
Wipe away any excess oil to prevent buildup.
Step 6 Service waterproof trimmers
Brush away any debrief.
Submerge only the removable blade assembly in isopropyl alcohol while the unit runs if the device is waterproof.
Rely on the vibrations to dislodge trapped hair or residue inside the blades.
Lubricate similarly with a few drops of machine oil and remove any excess.
Step 7 Reassemble and test
Reattach the foil or blade assembly after all components have dried completely.
Switch the device on briefly to ensure smooth operation and correct alignment.
Step 8 Warranty and long term care
Schedule regular cleaning and lubrication sessions to extend the device’s lifespan.
Perform all work safely to support a circular economy and reduce electronic waste.
Your razor or trimmer should now be clean, lubricated, and ready for dependable use. By following these steps regularly, you minimize the risk of damage and maintain optimal performance. Always remember to review the manufacturer’s guidelines regarding maintenance to preserve your consumer rights.
