How To Repair a Torn Silicone Apple Watch Band
Views: 2.3K
View statistics:
Past 24 Hours:
8
Past 7 Days:
44
Past 30 Days:
199
All Time:
2,324
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your Apple Watch's silicone band is torn, this guide provides step-by-step instructions for an effective repair. This method works for any Apple Watch model with a silicone band, helping you restore its integrity and prevent further damage.
The process includes carefully cleaning and bonding the torn area, with steps to ensure a smooth finish and a strong, lasting bond.
For best results, work in a well-lit, ventilated area, and handle UV-curable glue with care.
Follow each step closely to create a durable repair that restores your band’s usability and comfort.
    1. How To Repair a Torn Silicone Apple Watch Band, How To Repair a Torn Silicone Apple Watch Band: step 1, image 1 of 2 How To Repair a Torn Silicone Apple Watch Band, How To Repair a Torn Silicone Apple Watch Band: step 1, image 2 of 2
      • Gently bend the silicone watch band to get an idea of the size/severity of the tear.
      Ask FixBot
    2. How To Repair a Torn Silicone Apple Watch Band: step 2, image 1 of 3 How To Repair a Torn Silicone Apple Watch Band: step 2, image 2 of 3 How To Repair a Torn Silicone Apple Watch Band: step 2, image 3 of 3
      • Gently bend the watch strap to expose the inner part of the tear and use an alcohol wipe to thoroughly clean the area surrounding and inside the tear.
      • Allow the silicone band to air dry until no longer visibly wet.
      Ask FixBot
    3. How To Repair a Torn Silicone Apple Watch Band: step 3, image 1 of 1
      • Squeeze out a small dot of the UV curable glue onto a clean wooden toothpick.
      Ask FixBot
    4. How To Repair a Torn Silicone Apple Watch Band: step 4, image 1 of 3 How To Repair a Torn Silicone Apple Watch Band: step 4, image 2 of 3 How To Repair a Torn Silicone Apple Watch Band: step 4, image 3 of 3
      • Bend the watch band to expose the inner part of the tear.
      • Apply the dot of glue to the inner part of the tear.
      • Release the band from the bent position so that it lies in its natural position.
      • Using a new toothpick, wipe away excess glue that may have splurged out of the tear on both sides of the band.
      • Wipe the toothpick across the glue from the inner part of the tear to the outer edge of the watch band to create a thin, even layer of glue across the outer surface of the tear.
      Ask FixBot
    5. How To Repair a Torn Silicone Apple Watch Band: step 5, image 1 of 1
      • Cure the glue with a UV light for 30-45 seconds.
      Ask FixBot
    6. How To Repair a Torn Silicone Apple Watch Band: step 6, image 1 of 2 How To Repair a Torn Silicone Apple Watch Band: step 6, image 2 of 2
      • Gently bend the watch band to test the strength of the bond.
      • If the bond is not satisfactory, repeat steps 4-5 to strengthen the bond further and test again.
      Ask FixBot
    7. How To Repair a Torn Silicone Apple Watch Band: step 7, image 1 of 1
      • If remaining texture from the dried glue is not aesthetically pleasing, carefully use a nail buffer to smooth out any excess texture. (optional)
      Ask FixBot
Your Apple Watch band repair is complete. Allow the glue to fully cure before use, and avoid excessive water exposure.
Melinda
145 Reputation
1 Guide authored
UC Davis, Team 1-9, Morris Fall 2024 Member of UC Davis, Team 1-9, Morris Fall 2024
UCD-MORRIS-F24S1G9
2 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 44
Past 30 Days: 199
All Time: 2,324
