How To Repair An Overheating D-LINK DIR-655 Wireless Router
  1. How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 1, image 1 of 2 How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 1, image 2 of 2
    • Start by removing the three antennas by twisting each one in a counter-clockwise direction when facing the back panel.
  2. How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 2, image 1 of 2 How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 2, image 2 of 2
    • Using your flathead screwdriver or plastic opening tool, gently pry the top two screw covers out of the router's case.
  3. How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 3, image 1 of 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 3, image 2 of 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 3, image 3 of 3
    • Using your Phillips screwdriver, turn the screw counter-clockwise to remove it from the assembly.
    • Do the same for the second screw.
  4. How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 4, image 1 of 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 4, image 2 of 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 4, image 3 of 3
    • With your plastic opening tool or flathead screwdriver, separate the black trim from the white body of the route, working your way around the outside of the case.
    • Gently pry the top of the case from the sides and bottom of the router.
    • After freeing the top, remove it and set it aside.
  5. How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 5, image 1 of 2 How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 5, image 2 of 2
    • With your Phillips screwdriver, remove both screws by rotating in a counter-clockwise direction.
  6. How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 6, image 1 of 1
    • After removing the screws, lift the white LED cover up and off of the circuit board.
  7. How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 7, image 1 of 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 7, image 2 of 3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 7, image 3 of 3
    • Next, bend up the clip holding down the middle antenna wire.
    • Gently, unhook the wire and move it out of the way.
  8. How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 8, image 1 of 1
    • With the wire out of the way, separate the circuit board from the bottom assembly.
    • Be sure not to pinch or bend the antenna wire when you lift the circuit board.
  9. How To Repair An Overheating D-LINK DIR-655 Wireless Router: step 9, image 1 of 1
    • Wipe away any dust from the the vents to ensure proper airflow.
Chance Daniel
263 Reputation
1 Guide authored
Cal Poly, Team 10-6, Green Fall 2015 Member of Cal Poly, Team 10-6, Green Fall 2015
CPSU-GREEN-F15S10G6
3 Members
3 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 5,468
