How To Repair A Paint Stained Baseboard
Views: 1.2K
View statistics:
Past 24 Hours:
8
Past 7 Days:
32
Past 30 Days:
145
All Time:
1,210
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Baseboards often suffer from paint stains during wall painting or renovation projects. Over time, these stains can detract from the appearance of your room, making it look untidy. This guide will show you how to safely and effectively remove old paint stains from baseboards and restore them to their original condition, without damaging the wood. You’ll learn a step-by-step process using common tools and materials, making this a task anyone can accomplish.
    1. How To Repair A Paint Stained Baseboard, How To Repair A Paint Stained Baseboard: step 1, image 1 of 3 How To Repair A Paint Stained Baseboard, How To Repair A Paint Stained Baseboard: step 1, image 2 of 3 How To Repair A Paint Stained Baseboard, How To Repair A Paint Stained Baseboard: step 1, image 3 of 3
      • Lay down a drop cloth or plastic sheeting to protect the floor from dust and paint.
      • Use painter's tape to mask off the edges where the baseboard meets the wall and the floor to prevent damage to other surfaces.
      Ask FixBot
    2. How To Repair A Paint Stained Baseboard: step 2, image 1 of 3 How To Repair A Paint Stained Baseboard: step 2, image 2 of 3 How To Repair A Paint Stained Baseboard: step 2, image 3 of 3
      • Clean the baseboard with a solution of mild detergent and a clean wet cloth.
      • For stubborn stains or greasy areas, use wood cleaner or mineral spirits.
      • Wipe the baseboard dry with a clean cloth.
      Ask FixBot
    3. How To Repair A Paint Stained Baseboard: step 3, image 1 of 3 How To Repair A Paint Stained Baseboard: step 3, image 2 of 3 How To Repair A Paint Stained Baseboard: step 3, image 3 of 3
      • If the paint stain is raised or thick, use a putty knife or paint scraper to gently scrape off as much of the old paint as possible without damaging the wood underneath.
      • If using rubber gloves, put them on after using the paint scraper or putty knife.
      • Use 120-grit sandpaper to sand the stained area, smoothing out any rough edges and removing the remaining paint.
      • Sand in the direction of the wood grain.
      Ask FixBot
    4. How To Repair A Paint Stained Baseboard: step 4, image 1 of 3 How To Repair A Paint Stained Baseboard: step 4, image 2 of 3 How To Repair A Paint Stained Baseboard: step 4, image 3 of 3
      • Use 220-grit sandpaper to smooth the area further, blending it seamlessly with the surrounding surface.
      • This will help remove any fine scratches caused by the coarser sandpaper.
      • If the scraping or sanding has created any dents or gouges in the baseboard, apply wood filler with a putty knife to fill these areas.
      • Allow the wood filler to dry according to the manufacturer’s instructions, then sand it smooth with 220-grit sandpaper.
      Ask FixBot
    5. How To Repair A Paint Stained Baseboard: step 5, image 1 of 3 How To Repair A Paint Stained Baseboard: step 5, image 2 of 3 How To Repair A Paint Stained Baseboard: step 5, image 3 of 3
      • Use a paint brush to apply a coat of primer to the sanded and repaired area to ensure the paint adheres well.
      • Use a small paintbrush to apply paint to the repaired area, ensuring an even coat. Select a paint that matches the existing color of the baseboard for a seamless finish.
      • Apply a thin, even coat and let it dry completely before applying additional coats if necessary.
      Ask FixBot
    6. How To Repair A Paint Stained Baseboard: step 6, image 1 of 3 How To Repair A Paint Stained Baseboard: step 6, image 2 of 3 How To Repair A Paint Stained Baseboard: step 6, image 3 of 3
      • Once the paint is dry, carefully remove the painter’s tape.
      • Pull the tape at a 45-degree angle to avoid pulling off any paint.
      Ask FixBot
    7. How To Repair A Paint Stained Baseboard: step 7, image 1 of 3 How To Repair A Paint Stained Baseboard: step 7, image 2 of 3 How To Repair A Paint Stained Baseboard: step 7, image 3 of 3
      • Clean your tools with appropriate solvents (water for latex paint, mineral spirits for oil-based paint).
      • Dispose of any used materials properly.
      Ask FixBot
    8. How To Repair A Paint Stained Baseboard: step 8, image 1 of 3 How To Repair A Paint Stained Baseboard: step 8, image 2 of 3 How To Repair A Paint Stained Baseboard: step 8, image 3 of 3
      • Check the repaired area to ensure it blends seamlessly with the rest of the baseboard.
      • Touch up any imperfections as needed.
      Ask FixBot
Bree Cooper
178 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 32
Past 30 Days: 145
All Time: 1,210
