How To Repair A Baffle On A Patagonia Down Jacket
Video Overview
Down jacket baffle repair overview.
  1. How To Repair A Baffle On A Patagonia Down Jacket, How To Repair A Baffle On A Patagonia Down Jacket: step 1, image 1 of 1
    • Locate the hole in your down jacket. In order to prevent all the feathers from escaping through the hole, you'll have to replace the entire baffle.
  2. How To Repair A Baffle On A Patagonia Down Jacket: step 2, image 1 of 2 How To Repair A Baffle On A Patagonia Down Jacket: step 2, image 2 of 2
    • Cut a small oval of Tenacious Tape large enough cover the hole.
  3. How To Repair A Baffle On A Patagonia Down Jacket: step 3, image 1 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 3, image 2 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 3, image 3 of 3
    • Peel the backing off the tape, and apply it to the hole.
  4. How To Repair A Baffle On A Patagonia Down Jacket: step 4, image 1 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 4, image 2 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 4, image 3 of 3
    • Use a seam ripper to rip the seam at the end of baffle that needs a repair. In this case, the nearest seam is along the sleeve.
    • Rip a large segment of the seam, so that the jacket is comfortable to work with.
  5. How To Repair A Baffle On A Patagonia Down Jacket: step 5, image 1 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 5, image 2 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 5, image 3 of 3
    • Turn the jacket inside out.
    • Measure the width of the baffle you're working on. In this case, each baffle looks like it is two inches wide.
    • We are replacing two baffles, so we will need just over four inches of fabric to patch.
    • Measure the length of the baffle (along the baffle seam). In our case, the baffle length is nine inches, and since our repair is in the sleeve, we will double this to eighteen inches for the length of our scrap.
  6. How To Repair A Baffle On A Patagonia Down Jacket: step 6, image 1 of 2 How To Repair A Baffle On A Patagonia Down Jacket: step 6, image 2 of 2
    • Get a scrap of matching fabric to patch the baffle. Make sure you have enough fabric to cover the area you measured in the previous step, with an inch or two extra in each direction.
    • We are using a piece of fabric that is slightly lighter than our jacket, so you can easily identify which areas we are working on.
    • Fold one of the long edges of the fabric over so that it is straight.
  7. How To Repair A Baffle On A Patagonia Down Jacket: step 7, image 1 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 7, image 2 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 7, image 3 of 3
    • Iron the fold into place.
  8. How To Repair A Baffle On A Patagonia Down Jacket: step 8, image 1 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 8, image 2 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 8, image 3 of 3
    • Align the folded edge of the scrap along the outermost seam on the baffle you want to replace.
    • Be sure the rough, folded-over fabric is between the baffle with the hole and the new scrap of fabric.
    • Align the folded edge of the baffle with the seam, and pin it into place.
  9. How To Repair A Baffle On A Patagonia Down Jacket: step 9, image 1 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 9, image 2 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 9, image 3 of 3
    • Set the pinned piece into the sewing machine.
    • Be sure to use the smallest needle you can find to patch this baffle. This will keep the new stitch from looking too prominent and help prevent the down from escaping through the new stitching holes.
    • Sew directly over the old baffle seam. You will be sewing very close to the edge of the fold, just catching the fabric.
    • If you’re working on a sleeve, make sure you only have one layer of the sleeve and that you’re not sewing the entire sleeve shut.
    • Go slowly, and guide the folded edge of the fabric directly over the old baffle seam. You may have to realign the folded edge of the fabric as you go—that's okay.
  10. How To Repair A Baffle On A Patagonia Down Jacket: step 10, image 1 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 10, image 2 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 10, image 3 of 3
    • While you're sewing, be sure to hold the bias tape (which covered the seam edge) out of the way so that it doesn't get caught in the seam.
    • Continue to carefully sew the fold into place.
    • The fabric is very slippery, so be careful and take your time. Judge the seam to your liking.
    • When you come to the end of the seam, backstitch to keep your thread in place.
  11. How To Repair A Baffle On A Patagonia Down Jacket: step 11, image 1 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 11, image 2 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 11, image 3 of 3
    • We are working with three baffle seams in total. You've already sewn one at the outer edge. Skipping the baffle seam in the middle, pin the second fold into place on the seam at the other outer edge.
    • Sew the second seam as you did the first.
  12. How To Repair A Baffle On A Patagonia Down Jacket: step 12, image 1 of 2 How To Repair A Baffle On A Patagonia Down Jacket: step 12, image 2 of 2
    • Continue sewing.
    • When you are finished, your jacket should look like the second image.
  13. How To Repair A Baffle On A Patagonia Down Jacket: step 13, image 1 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 13, image 2 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 13, image 3 of 3
    • Turn the jacket right-side out again so you can see the original baffle stitching.
    • Be sure to flip the bias tape out of the inside of the seam so it doesn't get caught as you continue to sew.
    • Align your presser foot on top of the untouched, middle seam (between the two seams you've already sewed).
  14. How To Repair A Baffle On A Patagonia Down Jacket: step 14, image 1 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 14, image 2 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 14, image 3 of 3
    • Sew directly over the original middle baffle stitching between the two seams you just made.
    • Be sure to hold the bias tape out of the way.
  15. How To Repair A Baffle On A Patagonia Down Jacket: step 15, image 1 of 2 How To Repair A Baffle On A Patagonia Down Jacket: step 15, image 2 of 2
    • Trim off the excess fabric.
  16. How To Repair A Baffle On A Patagonia Down Jacket: step 16, image 1 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 16, image 2 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 16, image 3 of 3
    • For our repair of the sleeve, we need to realign the sleeve seam that we ripped.
    • Pull the bias tape out of the way.
    • Sew the sleeve seam closed, backstitching at the beginning and end of the seam.
  17. How To Repair A Baffle On A Patagonia Down Jacket: step 17, image 1 of 2 How To Repair A Baffle On A Patagonia Down Jacket: step 17, image 2 of 2
    • Replace the bias tape over the completed sleeve seam.
    • Adjust it so it sits correctly on both sides of the seam.
  18. How To Repair A Baffle On A Patagonia Down Jacket: step 18, image 1 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 18, image 2 of 3 How To Repair A Baffle On A Patagonia Down Jacket: step 18, image 3 of 3
    • Sew the bias tape back on. Make sure you sew as close to the inside edge of the bias tape as possible.
    • Backstitch at both ends of the seam.
  19. How To Repair A Baffle On A Patagonia Down Jacket: step 19, image 1 of 2 How To Repair A Baffle On A Patagonia Down Jacket: step 19, image 2 of 2
    • Inspect your seams. Make sure that everything is in place, clip your threads, and be very proud of yourself. That was a tough repair.
Brittany McCrigler
89,063 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,622 Guides authored
Past 24 Hours: 19
Past 7 Days: 120
Past 30 Days: 712
All Time: 176,786
