How To Hem Jean Shorts
View statistics:
Past 24 Hours:
3
Past 7 Days:
34
Past 30 Days:
151
All Time:
935
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 35 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will walk you through hemming jean shorts with a sewing machine. It’s a simple way to adjust your jeans to the perfect length and customize them to your style.
You don’t need advanced sewing skills—just a basic understanding of how to use a sewing machine and a few common tools. With careful measuring, cutting, folding, and stitching, you’ll end up with a clean, professional-looking hem.
    1. How To Hem Jean Shorts, How To Hem Jean Shorts: step 1, image 1 of 1
      • Use a ruler to measure and mark your preferred length of the shorts with fabric chalk.
      • Measure each side carefully and make sure both legs are marked evenly.
      Ask FixBot
    2. How To Hem Jean Shorts: step 2, image 1 of 1
      • Mark an additional line 1 inch below your chosen length to allow room for folding the hem.
      • Use sharp fabric scissors to cut across each leg along the lower chalk line.
      Ask FixBot
    3. How To Hem Jean Shorts: step 3, image 1 of 3 How To Hem Jean Shorts: step 3, image 2 of 3 How To Hem Jean Shorts: step 3, image 3 of 3
      • Fold the bottom edge of each leg up 1/2 inch, then fold it again to tuck the raw edge inside.
      • Pin the fold in place all the way around the leg to keep it secure.
      • Double check that both hems are even before moving to the next step.
      Ask FixBot
    4. How To Hem Jean Shorts: step 4, image 1 of 1
      • Place the folded edge of one leg under the presser foot of the sewing machine.
      • Lower the presser foot to the fabric before you begin sewing.
      Ask FixBot
    5. How To Hem Jean Shorts: step 5, image 1 of 1
      • Carefully sew along the folded edge, keeping the stitch even and close to the inside edge of the fold.
      • Backstitch at the beginning and end to secure the seam.
      • Repeat the same process on the other leg.
      Ask FixBot
    6. How To Hem Jean Shorts: step 6, image 1 of 2 How To Hem Jean Shorts: step 6, image 2 of 2
      • Once the hems are sewn, trim off any loose threads.
      • Use an iron to press the hem flat for a clean finish.
      Ask FixBot
Finish Line
Tiffany Ngo
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 34
Past 30 Days: 151
All Time: 935
